Old 10-23-2008, 05:03 PM   #19
kou
Drives: 08 lb
Originally Posted by Sodium Duck View Post
Why are there holes in my car to begin with...?
Is this where the welding bot went, or some kind of screw on the inside, or to hook the car up to an assembly line...?
when the car is shipped thats one of the tie down spots.
Old 10-23-2008, 08:23 PM   #20
YAR1S
YAR1S's Avatar
LOL. I put these in finally today. Also found out my muffler hangers were rusted out, its a pretty common thing suspossily for yarii. Oh well....
Old 10-23-2008, 08:24 PM   #21
YAR1S
YAR1S's Avatar
Arnt some of the plugs/holes for drainage if you were to drive your yaris into a flood, LOL>
Old 10-23-2008, 10:32 PM   #22
gid
yup , go in those holes .
Originally Posted by tristan View Post
so they DO go in those holes?
don't get me started on HOLES . Anyway , may want to check the plugs where your spare tire is located ( need to remove ) . I found the larger plug to be loose and as a precaution put clear shipping tape over those plugs to keep more secure , plus the clear tape will help to see if plug is loose . If you do so , clean the painted metal surface around the plug(s) so tape sticks better .
Old 10-23-2008, 10:40 PM   #23
gid
don't forget your ...
rubber duckie .
Old 10-24-2008, 08:41 AM   #24
500snakz
500snakz's Avatar
Drives: 08 Polar white hatch
PLUGS INTO THE HOLES OF THE CENTER FLOOR SIDE MEMBER EXTENSIONS.
500snakz is offline   Reply With Quote
Old 10-24-2008, 09:52 AM   #25
k2vitz
k2vitz's Avatar
Drives: Vitz 2006
I got similar plugs; went to the delearship. They jacked up and found these already installed. The bag is still in my glove box.
k2vitz is offline   Reply With Quote
Old 12-16-2008, 09:07 PM   #26
b_hickman11
Drives: 08 Sedan
Did we ever find where these plugs go?
Old 12-17-2008, 12:06 AM   #27
YAR1S
YAR1S's Avatar
yep.
Old 12-17-2008, 12:08 AM   #28
YAR1S
YAR1S's Avatar
look just in front of your rear tire wells... they are usually missing from there..... if not, look for some unplugged holes in the front...
Its kind funny actually cause i went to my mechanic today and when he had my yaris jacked up i had a look underneath and there are SOOO many holes that have some sort of plug in them..... they could literally be for anything but generally by the shape the ones found in gloveboxes go in the holes just in front of the rear tire wells... or vise versa for the front wheel wells.
Old 12-17-2008, 07:11 AM   #29
b_hickman11
Drives: 08 Sedan
Thanks! I also looked underneath and there are about 6 of these holes and wasnt for sure which ones I was suppose to stuff.
