#19 |
ive been running a nitrous setup in my scion tc which has a plastic with a 50 shot dry set up has the same no return line fuel pressure dont have to worry about it the wet system has to up the fuel pressure to prevent a drop in fuel pressure due to the valve opening up when nitrous is turned on mine runs on a rpm based window switch from msd turns on at 3000 rpm so long you are running full throttle and octane above or at 92 your fine. ive ran dry systems through 4 cars already no problems my scion tc, 2 acura rsx, and scion xb. wet systems are more common to engine backfires due to the fact of fuel being added dry systems are not.
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
#20 |
a 755 hp crx?!
#21 | |
Drives: yw calls me douche and racist. Join Date: Aug 2007
#22 |
ls block sleeved
gsr head stock cams je pistons crower rods rc 1200cc injectors aeromotive a1000 fuel pump garrett gt 4294 sumped tank odx diff dss stage 3 axles skunk 2 intake manifold gsr trans made 755 whp with a chrome tune previous set up ls sleeved gsr head ls bottom end eagle rods je pistons garrett t 60-1 dsm injectors gsr trans stock axles stock trans made 504 whp the difference to jump to 755 $4000 built the car had it already to go then they closed the track so now it just kinda sits there and chills and yeah that was kinda of a mouth full
#23 |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
#24 |
Beast
well imo (not that you are asking for it) i don't really appreciate nitrous. Its like chugging down a steroid drink or something. its better to spend money on other performance mods. Too many kids running around with 2 bottles of NOS on the back of their stock hatchback civic swearing they are god.
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#25 | |
#26 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
The only time nitrous should be used is when you have a massive turbo to spool up
![]() Nitrous does have its place... Its super cheap for the power you get. But remember it can get expensive if you have to keep refilling the bottle. So sure its cheap the 1st bottle and the 2nd bottle... but what about the 10th bottle? or 20th bottle? at that point you might want to consider some form of forced induction or n/a bolt-ons instead. My 2 cents.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#27 |
![]() ![]() ![]() ![]() Drives: 07 metmet LB Join Date: Oct 2008
Let me start by saying I've never owned a F.I car or one with nitrous......
I get annoyed when people call nitrous "cheap" or "sneaky" or call those who use it cheaters. Why exactly is that? Is not a professional tune or upgraded turbos on a stock looking car "cheating"? I don't get it. A turbocharged mustang that makes 400whp is awesome but a mustang that makes it on spray is looked down upon oftentimes. On the same note, using racing octane gas at the track is cheating too. If i am at the track and have the opportunity to drive one of two cars....i'll pick the faster one...whether its on spray, whining or spooling. End speech.
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
#28 |
Nos isn't any worse than a Turbo is. Just don't run ridiculus shots and you'll be fine. Same with a turbo. Don't run an insane boost number, and you'll be fine.
#29 |
![]() ![]() ![]() Drives: 2008 Yaris hatch Join Date: Oct 2008
Before testing on the lkow-buck turbo system began, we ran tests on a 40-hp shot using an NOS kit on our Yaris. We ran through a whole bottle atthis power level and never had any backfires or intake damage due to temperature. I have run nitrous with composite intakes on a wide variety fo different applications (inlcuding the 1.8L Scion Xb) and never had an issue with cracking. We even ran the 40-hp jetting on our modified Yaris (120 wheel hp before the nitrous). The result was (peak numbers of) 162 wheel hp and 155 lbs. ft. of torque on the 1.5L Yaris. This was a wet kit injecting nitrous and fuel between MAF and throttle body. Their cracking intake theory is just that-a theroy-real data always works best.
#30 |
i ran a 40shot with no issues.. it would take a very large amount of nitrous to crack your intake manifold..
| Nitrous Oxide Systems, Yaris on the Bottle | CASTREX | Performance Modifications | 20 | 07-15-2007 10:40 PM |
