Audio Junky
added air to my tires.
So... winter months coming... temps dropped and I noticed that my mpg's went from consistently 43+ to anything in the 40-42range. My last tank (although a small tank) was 40mpg's.
I decided that there were 3 main factors. 1: car taking longer to warm up 2: Tire pressure had dropped from 40psi in the summer months to 32psi currently 3: Due to colder temps... air resistance is higher due to the air being more dense. Can't do much about problems 1 & 3... So I pumped the tires back up to 42psi. First tank afterward netted 43.71, which is the higherst i've gotten since august 31st. Haven't noticed any difference in performance/handling or comfort either. So I'm happy with my 1-2mpg I gained back. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
Don't forget winter gas is probably in your tank now as well. I've read where people check their tire psi weekly in the winter.
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Just get Nitrogen gas put into your tires and you wont have to worry about decreasing psi, no matter what the temp is outside. Most dealers in my area now offer this and it is usually free.
Audio Junky
well.... isn't air 80% nitrogen anyways?.... I'm fine for now.
Audio Junky
maybe... oregon always has ethanol in the tank... has for years... so other than oxygenating it I don't know what would be different.
Nitrogen is denser than oxygen. Thus harder for it to leak out. With oxygen you loose about 1 pound of air per month slowly from your valve stem. With nitrogen you loose maybe 1 pound every 6 months to a year.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I run a special mixture for my tires.
78.1% Nitrogen 20.95% Oxygen 0.038% CO2 0.0018% Neon 0.0005% Helium 0.0001% Krypton 0.00005% Hydrogen Free Nitrogen is one thing, but to pay $5 a tire like some places charge is another. I'll save my money for snake oil.
Making a decision without following it with an action is still a fantasy. |
It's like the bottled water craze, where often people are paying for bottle water that's even worse than the water coming from their taps.
#10 | |
Party like a Barack star
Drives: '08 LB MT Join Date: Oct 2008
Personally, MPG takes a back seat to my safety and the safety of my passengers
i don't feel like creating another signature, yet. Give it another week... |
42psi in your tires? are they worn down the center?
damn, i ran too high of a tire pressure in my winters one time and i had to buy 2 new fronts by the end of the season (and i didnt rotate them) as they were on the wear bars down the center of the tire....
^^^ He speaks the truth... It's hard to convince people otherwise, but it doesn't save you money by over-inflating your tires; sure you get higher MPG, but you are replacing your tires more frequently offsetting the savings.
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
As in most discussions, compromise is good. Standard pressure (in the summer) is tough on fuel, but good for traction (in the winter). High pressure that wears only the center is bad, slightly higher pressure to save fuel is good. I run 4-6lbs over sticker, tires are wearing evenly, fuel economy is excellent, traction is just fine.
One can ALWAYS go "too far"... |
#14 | |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
damage suspension as well ...
from the variation of temps . Try to check them every week if you can .
#15 | |
There is a growing number of people who inflate to maximum sidewall pressure and beyond with no ill affects and loads of various benefits like better MPG, handling, braking etc. Any statements to the contrary are made by people who do not know the facts. My latest pair of winters have been at a constant state of 50 psi or more and same goes for my current all seasons. I have over 40,000 combined kms on these tires and they still exhibit virtually no wear. Inflating to maximum sidewall and a little higher has only one downside and that is ride comfort, anyone telling you any different either doesn't know what they're talking about or is a liar. |
#16 | |
Thanks! I'm glad to know that Yokohama has wasted tens of thousands of dollars and countless hours training me on tire manufacturing, tire construction, tire conditions and more. I could have saved my company TONS of TIME AND MONEY if I had just come here and asked you about the "facts"... ![]() ![]() ![]() ![]() ![]() ![]() By the way: an "over-inflated" tire would be one that exceeds the vehicle manufacture's recommended air pressure.
#17 |
had winters @45psi for 20kms one winter and had to replace the front tires the following year. that being said, i had my xrs which would often lose traction at lift in cold weather...
i run 36psi daily though so i guess do whatever you want! lol
#18 |
DWEED
I always do what the manufacture and the tire dealer recomend. I figure that the professionals know best.
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 06:40 PM |
| $7 Ram air intake pictorial | turbodiesel | Performance Modifications | 19 | 10-27-2008 05:46 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 01:23 AM |
