#19 |
Plus a supercharged yaris just seems right for some reason...[/QUOTE]
![]() ![]() Hell yeah
Clinging to my guns and religion down here in the south. Come and take them! |
#20 |
Bathroom + Laptop = <3
bahhhh that jackass that was selling the supercharger for cheap took it offline, what an asshat...kind of pissed right now, trying to see if i can find another deal...
#21 | |
getting your pulley to line up perfectly will be an issue, and making a bracket strong enough will be difficult without aluminum.. |
#22 | |
Break'em off some.
You are better off going with a centrifugal blower or turbo. |
#23 |
![]() ![]() ![]() Drives: 2008 Yaris hatch Join Date: Oct 2008
I have some experience in designing and building supercharger kits(we designed and built the blower systems for Stillen on the Maxima)-here are a few tips. The belt alignment has to be perfect in every axis or you will throw belts. The blower can blow through the MAF,but it will be much better to draw through the MAF and the throttle body should be mounted in front of the supercharger, not on the manifold in stock configuration. You can run without a bypass valve by air temps will go up significantly under cruise conditions and will use more fuel this way (increased parasitic loses). I doubt the stock MAF will be able to cope with additional airflow from blower, but might work at lower boost levels-we have had good luck in NA applications up to 123 wheel hp so far. Blower needs to be rigidly mounted using mounting plate to engine to keep belt alignment true-this takes some design work. It is a good idea to have blower blow through stock intake as this will help ower compared to blitz set up with short runners. This is not something that can be thrown together, but it can work.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
I'm halfway through a Biltz installation right now and the engine compartment is getting very crowded. As Richard said, whatever you throw together had better make sure all your pulleys are lined up and parallel.
From the picture in the original post, you might need to cut a hole in your hood cause that sucker is big! Like largeorangefont said, you need to build a new intake manifold or get Richard to make you one. I don't know what are the major cost drivers in a complete supercharger kit but the compressor is only a part of it.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#25 |
§†ęĄ¶‡Ћ-NCP96
DO IT DO IT !
#26 | |
#27 |
Thanks for the advice Richard, and its good to hear the MAF would be able to handle it...
I will not be making a new intake manifold just utilizing the stock one with a connecting pipe, the air does not need to be direct as it still holds the same pressure charge.... with an intercooler, it will cut down on bends in the pipe work... but you are right, the mounting will take alot of work if not the most... I have my cardboard and scissor ready ;) But i still have a couple of recirc valves from an S4 and a small intercooler to boot This is pretty much what it will look like, might be ghetto, but a supercharger setup that is cheap, would you argue?
#28 | |
I love this home made stuff-you should see my compound turbo system on my 1987 Sprint-full Mad Max style.
#29 |
SIPNDEW
whats the part number off of that supercharger. im going to see what my cost is on it.
#30 |
It is an Eaton M45, P/n 117159-10,7526657-01 ....surprised i found that... Got any pics of the Turbo Sprint Richard?
No pics means it didn't happen ;) I would love to see it though |
#31 |
a turbocharger can be had for $50
a cast manifold for $180 but hey, good luck ;) |
#32 |
turboing just has more knitpicky parts :-/ thats the only reason im not doing it...
but supercharger, ohh man... Woooooooo....Woooooooooo...WOOOOOOOOOO |
#33 |
Vroom Vroom Beep Beep
If you do this your my hero.
#34 |
#35 |
oil lines/coolant lines/AN Fittings/Having to tape the block/pan/Wastegates/Boost Controllers/Intercooler/ More Custom Pipe work/etc....
Supercharging is based off the intake side, which means i do not need to do pipework, just making flanges with pipes. There is a perfectly substitutable flex pipe in the marine world that holds up to70psi of boost and has good flow. Albeit it being Orange(maybe wrap it with electrical tape or some crap, variety of colors now), it is still somewhat pricey, but i think it will save tons on costs versus piping. If it could withstand the hotside of a turbo, i would've did that, but almost all silicone/rubber melts at those degrees... And it is not like i am trying to build a monster here, the supercharger with a reduced pulley can make some good power... If i were trying to make a drag monster/track warrior... I would not keep this engine at all unless i had about 10k to throw into internals... |
#36 | |
you tee into the oil pressure sensor already tapped at the block. no one says you have to use AN fittings ;) you don't have to tap the oil pan, use a sandwich adaptor. run the oil coming out of the turbo into your oil cooler and back into the engine turbo: you won't need a wastegate as most small turbos are internally gated which also means you don't need a boost controller you don't need an intercooler on low boost applications and believe me, piping is much easier to fab than a bracket with "rough measurements" to hold a supercharger spinning 4X engine speed. you can use that silicon exhaust hose for the charge air coming out of a turbo too ;) |
