Paddle Shifting (for MT)
good afternoon everyone..
i am in the process of building a paddle-shift system to be used on any manual transmission that utilizes cables for shifting. the system will utilize two pneumatic cylinders with positional feedback switches, 4 three-way pneumatic valves, a PLC, a small air compressor and tank, and switches mounted either to a sandwich adaptor (for aftermarket 6bolt steering wheels) with paddles integrated or limit switches to be mounted under the shifter to sense fore-aft motion. i currently predict this kit to sell for around $1000.. anyone interested? |
SIPNDEW
well it definately sounds awesome! i am more of the normal manual shift type but for those who want paddles its your chance! :)
fyi your clutch will be fully functional (and required) and i will integrate a small air cylinder to blip the throttle on downshifts..
SIPNDEW
thats cool. but can you retain the stock shifting mechanism for street driving if you choose?
Looking forward to pics and a review of your prototype
![]() ![]() ![]() ![]() Drives: 07 metmet LB Join Date: Oct 2008
This would be cool as sh*t
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
Bathroom + Laptop = <3
http://www.m7tuning.com/parts/produc...roducts_id=123
Mini also has a system like this you might want to check out for ideas and whatnot... looks promising.. |
Beast
would they work in AT? i got confused by the website selling em for Automatic?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#9 | |
first, it's only for transmissions with the stick ON the trans (RWD setups) second all they show you is pretty pictures of the paddles. here's my work so far my initial design will be for MT only. here's my chicken scratches from last night.. ![]() and my truth table.. gotta integrate this into the programming now.. my brain hurts ![]() i1-i4 are cylinder position feedback inputs (so the PLC knows what gear you're in) i5 is "upshift" input from the paddles i6 is "downshift" input from the paddles Q1-Q4 are outputs for the valves that will control the cylinders |
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
![]() great work! |
well, I'm certainly interested in the technology behind it, it is an awesome project, too bad you can't integrate the clutch
well doing it as a clutch override would be ideal I guess, so you retain normal control of it. Seeing as it's a hydraulic setup (at least on our cars, not sure about the xA), it should be possible given the right engineering? Or maybe as a future upgrade
#14 | |
entirely possible. this unit will most likely have a throttle blip on downshifts.. to do clutch you integrate a large number of things and will require a plc that costs about triple of the little Siemens unit i'm using (6 inputs, 4 outputs) |
#15 |
all right, gotcha
it'll still be pretty awesome as you are planning it!
#16 |
§†ęĄ¶‡Ћ-NCP96
#17 |
well, i just finished the PLC program.. i know a screenshot is pretty useless, but this is what 7 positions look like (1-5 + N + R) and what it takes to cycle through all of them.
![]() i'm not gonna mess with the program anymore until i get all the components here.. checking the interlocks without physical movement is making me go cross-eyed |
#18 |
i modified a stock shift cage to only go forward and backwards.. will mount this guide plate in place with a spring load to keep it centered, then limit switches will be mounted on the other side of the plate
| Didn't buy; awkward shifting? | drmitch | New YARIS Purchase Forum | 89 | 03-03-2009 09:44 AM |
| Yaris Auto Transmission shifting | g man | Canada | 9 | 08-23-2007 12:16 PM |
| Shifting (A/T) | daq421 | General Yaris / Vitz Discussion | 54 | 04-03-2007 12:30 PM |
| Paddle Shifter? | spkrman | Performance Modifications | 10 | 03-09-2007 05:17 PM |
| Sticky When Shifting and Sticky When Reving? | jouslee | DIY / Maintenance / Service | 22 | 01-23-2007 11:07 PM |
