Old 11-17-2008, 05:09 PM   #127
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
What is the color code for meteorite metallic on the Visual Garage site?
There are three kinds of "gray" there. Which is the right one?
1E7 - Silver Streak Mica
1F8 - Metalliceroite Metallic
1G3 - Magnetic Gray Metallic
Old 11-19-2008, 08:18 AM   #128
djgab101
djgab101's Avatar
Drives: toyota yaris
i have a short antenna it does lose a little little bit of signal ..... i heared the shark fin is terrible !!! it has bad signal .... the shark fin was not made for the yaris radio!
djgab101 is offline   Reply With Quote
Old 11-19-2008, 12:17 PM   #129
Revsson
My 2009 LB spec sheet that came with the car says color 01F8.
So, I assume that 1F8 is the color for your LB. Apparently, they didn't
do a spellcheck or don't know how to spell Meteorite.
Perhaps you can point that out to them if you do order one.
Old 11-19-2008, 03:43 PM   #130
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thanks Revsson! I didn't buy my car new so I don't have that spec sheet.
I wasn't too sure if that was the one because of the spelling! Much appreciated
Old 11-19-2008, 05:19 PM   #131
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
did someone say shark ? ...i couldn't resist.
id3379 is offline   Reply With Quote
Old 11-19-2008, 06:09 PM   #132
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
looks more like a pirahna
that's cause its a yaris..
Old 11-19-2008, 06:26 PM   #133
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
lmao ^^
Old 04-09-2009, 04:19 PM   #134
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Just ordered my Sharkfin. Can't wait!
Old 04-11-2009, 04:40 AM   #135
JustAnotherAsian
now in HD
Drives: not yaris!
Send a message via AIM to JustAnotherAsian
whoa. probably my longest thread so far. a thread concerning... sharkfin antennas. haha.
JustAnotherAsian is offline   Reply With Quote
Old 04-11-2009, 02:40 PM   #136
CanadianHiFive2
Drives: Sedan
Sedan?
Is it possible to install this in the 2007 sedan cause i know the antenna is in the rear window but could u cut the wire from the HD and then just run it up to the roof. Just throwing this out there have no idea if itll wrk
CanadianHiFive2 is offline   Reply With Quote
Old 04-11-2009, 06:51 PM   #137
yaris-me
Learn to Relax
You can get an antenna repeater. Bottom of page.
http://www.sigmaautomotive.com/FoliaTec/antenna.php
Old 04-21-2009, 04:46 AM   #138
yaris-me
Learn to Relax
Got my Sharkfin antenna today. Installed it and tried it out. On the open road, the reception is the same. The only difference is in parking structures. I lose the weak AM stations and the strong AM stations pick up static. The FM stations are the same.
