Old 11-23-2008, 04:30 PM   #1
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
VIP RS3200
I got VIP RS3200.
There are 2 things I found werid.
1) When I lock/unlock the door, the alarm gets armed/disarmed, but it doesn't not make the beeping noise. I looked at http://www.etimago.com/yaris/repairm...0Deterrent.pdf and saw there is a thing called security horn all the way at the end of the PDF document. Do people actually have this horn? Is my alarm not making beeping noise when armed/disarmed because I don't have this horn? Does anyone have picture of it installed there?
2) The manual that came with the alarm system is saying it will make warning alarm sound when the window is tapped, but mine doesn't. It does nothing even if I hit the window pretty hard. Is this same for everyone else with this alarm?
Just wondering in case they did not install mine correctly.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 11-23-2008, 05:04 PM   #2
IsLNdbOi
IsLNdbOi's Avatar
My 5-door '09 LB had the RS3200 pre-installed. It doesn't make the chirping / beep noise either when I lock / unlock the car using the remote.
Old 11-23-2008, 08:15 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
too bad i did not have my RS3200 installed on my echo for long enough before i sold the car. I did the install myself.. and it came with a peizo buzzer that makes a chirp sound (once to lock and twice to unlock) I had to run that thing through the firewall to wire it up to the module.
I do not believe the RS3200 alarm system comes with any shock sensor. ie, tapping the window. The alarm system has an immobilizer and lock/unlock sensors, but all of this is very mechanical.
What you can do to test it out is roll down the window so that you can reach the inside door handle from inside... arm the car and try to open the door. if it sets off. it's working.
Extreme VIP Style Yaris Walter Photo-Video-Media Gallery 30 09-13-2007 02:53 PM
VIP Kit?? jznomoney In Car Entertainment + Electronics (audio / video / alarm) 3 06-21-2007 03:21 AM
Toyota VIP Security - Plug and play? shagrat In Car Entertainment + Electronics (audio / video / alarm) 22 04-19-2007 06:37 PM
anyone get the VIP alarm for their yaris?? static808 General Yaris / Vitz Discussion 1 01-09-2007 01:46 AM
toyota vip rs3200 alarm system and key with integrated remote manborn In Car Entertainment + Electronics (audio / video / alarm) 0 10-16-2006 06:02 PM
