Old 11-24-2008, 09:22 AM   #19
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Napa sells a good one as well. It fits the filters perfectly.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 11-27-2008, 12:53 PM   #20
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by auxmike View Post
I splurged and bought 10 washers for $10 from the dealer.
Penny wise and Pound foolish can cost you a lot in the end.....
Thats not pencewise - thats a ripoff. Its a goat-mule sacrifical drain plug washer not even remotely high tech. Boy, you americas throw your money away like its been given too you by rich daddy! Drive up coffe for three euro a cup and complain about gas cost. Very Hilarious! I'll save the buck and buy the next better grade OIL FILTER or Euro Oil where it may do something good for the motor. If you dig through garbage for food and cloth 1/2 your life you will not be so cavalier about throwing money away. So Brass washer, hot plunged in zinc or stannum will do great for "crush washer" So is it 14mm or 12 mm DIA?
Old 11-27-2008, 01:25 PM   #21
auxmike
auxmike's Avatar
To each his own.
Old 11-28-2008, 10:16 AM   #22
TheSilkySmooth
To each his own.
Yeah, I like the toyota washer, Good for 3 uses at least, but a buck? I am still on the original after 4 OC and time for new, We used spark plug washers in europe but no parts guy seems to carry anymore. Maybe with advent of $$$ iridium-tip sprak plug the replacement washer will come back. On the spark plug you shouls ALWAYS putting on the new crush-washer if you pull a plug. I see many Subaru's with toasted heads from backed out plugs and reused washers.
back into the oil pan = Guys, just do not substitute with a zinc-dipped steel in the vintertyme - it will dissapear (rusting) if you getting the salz-wasser on it!
Sonja's bro
Old 11-28-2008, 01:46 PM   #23
gid
here's a car ramp D.I.Y. ( for gear , motor oil change , etc. ) , go to http://s49.photobucket.com/albums/f2...t=IMG_1243.jpg . Could use 1 level for ramp instead of 2 ( plenty of clearance with 1 board ) . Then put 1 piece of wood across each end of board ( stoppers ) to prevent driving of ramp . Should take less than 1/2 an hour to cut and nail . This is from SCIONLIFE for an 1st generation XB , a cousin of the YARIS .
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-24-2008 12:45 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 04:25 PM
Toyota oil filter difference in sizes? pics Ogredude DIY / Maintenance / Service 7 04-02-2007 02:16 PM
