![]() Drives: YARIS Join Date: Dec 2008
Recommendation for Shocks?
This is my first post. Well, I would like you guy to recommend shock for me. Now, I'm using H&R spring and I would like to get new shock that give me a smooth drive. In my mind, I just look for Tein, Tanabe, and TRD. Which one would you recommend?
Thank you. |
Tokiko
Vroom Vroom Beep Beep
Tokico will stiffen it up a bit. For smoothness KYB should suffice.
Tokico and KYB both are the manufacturers of the TRD Sportivo shocks. My TRD's are made by KYB. They are good, but non-adjustable. I got some Tokico "Blues" for my dad's Camry, and the ride got mildly stiffer (again, Tokico Blues are probably the same ones as the TRD's).
KYB do manufacture the TRD shocks (mine at least) but the difference is the damping rates.
The TRD shocks produce excellent handling but at the sacrifice of ride comfort. If you want a "smooth" ride find a shock with much less damping than the TRD's. The KYB GR-2 shocks may be your answer. They are an OEM replacement shock with slightly greater damping than the stock units. I've enjoyed them in my previous ride (Eibach lowered Talon) and the ride comfort was maintained while still controlling the stiffer lowering springs adequately. Good Luck!
What?
Look at your ride height. If the car has too little suspension travel, you're simply NOT going to get a "smooth drive". The problem with going too low is that you reduce the stock 3-4" of bump-absorbing suspension travel to less than 2". If you didn't cut the bump stops, you'd be ON them at rest. If you did cut the bump stops, you've got a whole inch before you contact them. This means that with stock shocks and typical off-the-shelf lowering springs, you're going to blow through what little travel you have on almost every bump. You'll at least get into the bump stop, which will make the ride harsh. If it's a larger bump, you'll compress the bump stop making it even harsher.
To run super-low ride heights on a race car, WAY stiffer springs and corresponding stiffer shock damping is used to make the most of the available suspension travel. None of that adds up to a smooth ride. To recap: You're not going to get a smooth ride on a street car that's been lowered too much. |
I wouldnt go with a oe replacement since you car is lowerd. My experience kyb can be blown out easily in 15k miles on a lowerd car. Depending on where you live and how you drive. You are better off getting set of shocks that are specificly designed for lowered cars such as tokiko shocks. I saw a video in school once how they test every shock before packaging. I would say they are very high quality.
#8 | |
TehXFallen has the same combo now and I'm always surprised when I ride in his car how perfect that combo feels for the Yaris.
What?
"Smooth" is a very subjective thing. It depends on your personal tastes, and on what kind of roads you have to drive on every day.
My preference is always what I call "firm, but not harsh". I don't know how much height you lose with the H&R springs, that's why I urged the OP to look at his ride height and make his own observations. |
#10 | |
Thank for reply My H&R spring is about 30mm drop. Well, which shock would you recommend me. However, it'll better, if I'm change the whole set (Spring & Shock). Thank you |
#11 | |
What is model # for Tokiko shocks (the one that same as trd shocks) Thank in advances. |
#12 | |
Do you which model is same spac as TRD shocks (for yaris). Thank you. |
#13 | |
KYB GR-2 is suitable for Yaris right? Thank you. |
#14 | |
and you can support a yarisworld vender. I think there was another vender selling the same set also. |
#15 | |
On that note, I had GR-2's on my GTI with some Megan lowering springs. It was a pretty smooth ride. Not as stiff as my Yaris' ride (probably due to the S.Techs). |
#16 | |
Thank you Well, your tanabe shocks is adjustable shocks, isn't it? and is it "Tanabe Sustec Pro" right? |
#17 | |
Well, which one would you guy recommend me btw Tokiko or KYB.
Thanks in advance |
| Fire Extinguisher Recommendation? | stran | General Yaris / Vitz Discussion | 7 | 12-10-2008 10:12 PM |
| Tire Recommendation? | ic210 | New YARIS Purchase Forum | 8 | 11-04-2006 09:32 PM |
