![]() Drives: 3 dr 1.3 2NZ Join Date: Dec 2008
Storing car for 3 weeks, any special preparation?
I'm going off for a 3 weeks vacation and won't be driving my Yaris. Any special preparation for the car beside parking it in the garage and pump up the tires a bit?
![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
nope
![]() Drives: 08 lb Join Date: Oct 2008
change oil when you get back...
wouldnt think so...
Slowy getting there
Battery may not like you when you get back. A trickle charger might help. Not sure how long it would take to drain the battery
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
make sure the lights are turned off
a battery should be more than fine for 3 weeks
Three weeks? I wouldn't even bother pumping up the tires for that short amount of time...
And unless your battery is over three years old, it shouldn't be a problem either. I park my cars for several weeks all the time due to work travel. My 10-yr-old Passat handled it fine, and I expect my Yaris would do likewise. Cheers! M2 |
i had the aveo parked for a couple months in winter (think -20c) and the battery was still fine
left the car sitting for almost 10months and everything else was fine... i dont think parking for 3weeks youll really have to do anything at all, except lock the doors
![]() ![]() Drives: 07 Yaris Hatch 5speed Join Date: Nov 2006
If you have a fancy car alarm, it could run down your battery, so you might want to charge it when you get back.
Disconnect the battery, it's not nessasary but it may stop a dumb thief while your away...
only one preperation, prepare for the possiblity of a little whif of that new car smell coming back again when you first open the door. Happened to me after a week of non use afer owning the car for a year and a half. Nice littls surprise.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
prepare for the excitement when you set yours eyes on your like-new again yaris... it will miss you im sure and you... it.
:p |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
if it's indoors: (yes I would say some of this is extreme but some people are just over cautious)
make sure all windows are rolled up and doors are shut plug the exhaust tip with something or rubber band a rag or two over it put the car on jack stands to avoid flat spotting the tires remove the negative battery cable and wrap it in a rag or two and shove it down where it will not come in contact with metal plug the intake tube or wrap rags around it some people add fuel stabilizer it's really up to you when you get back: check the psi of all tires including spare REMEMBER TO REMOVE PLUGS FROM INTAKE AND EXHAUST run the car for about 5 minutes just idle in park to run fuel through the lines when you first drive it again drive it w/o hard acceleration as the fuel maps will need to be relearned by ECM/PCM |
#15 | |
I agree with disconnecting the battery, but that is all I do, and I store cars all the time for way longer than that.
definately make sure every opening is closed... dont want any critters taking up home.
#17 | |
Three weeks is nothing, and even a heavy alarm system shouldn't draw enough power during that time to drain the battery... |
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Regular car wash, or Dealer car wash? | Buckethead | Wash, Wax, Detailing, Exterior Repairs | 49 | 07-21-2007 12:46 PM |
| my car got stolen this morning | leamsi | New YARIS Purchase Forum | 59 | 03-24-2007 02:50 AM |
| REALLY BAD CAR ACCIDENT! | MacMaster761 | General Yaris / Vitz Discussion | 25 | 11-30-2006 11:20 AM |
| [Detail] [as to make ] Auto Laudering | Sérgio Barros | Wash, Wax, Detailing, Exterior Repairs | 4 | 08-22-2006 03:56 AM |
