#19 |
"Gettin Jiggy wit it"
long running of engine
Do not worry about damaging your engine, with it idleing for 1.5 hours in temps that low. The worse thing that you probably did was build up a little bit of carbon deposits. If you ran the car every day idling that long you could clog your cat converter.Take it out on the highway and clean it out a little bit.
I have worked on engines all my life, every thing from car engines, diesels, to jet engines and as long as your cooling system works properly you won't hurt the car. With the extra cold weather we get in New England, you need to properly warm your car up. Today was 5 degrees out and I warmed mine for about 5 minutes before driving off. Good luck with your car and put your mind to rest. |
#20 | |
![]() ![]() Drives: 08 sedan auto Join Date: Nov 2008
#21 |
same amount of posts lol
Drives: 07 Meteorite Metallic LB Join Date: Jun 2007
i left mine on for about 3 hours while i was in class...i was up studying all night and had a test so i wasnt completely there, left it running with the a/c on in the parking lot, on the way back to my car i thought i lost my keys, i get there and the car was running...i felt so dumb...lol
#22 |
I do the same thing even when I'm getting gas. I'll take the keys out but still crack open a window...you never know what can happen, right?
#23 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
agree ...
the car idling for that long period of time is not beneficial . I highly suggest that you get your oil changed soon as possible . Long idling can lead to fuel dilution , which can thin the oil , thus leading to premature wear . GOOD LUCK
#24 |
if you leave a car running for long period of time it can lead to valvetrain damage , rings , or other due to the extreme heat . That's why you have a cooling fan , which is no substitute for air passing through the radiator at faster speeds . An acquantance left his new MUSTANG running all night in the garage and noticed smoke would come out of tailpipe when started after the mishap , most likely from overheating the valves or piston rings or both . He decided to trade it in for a new COROLLA . Figured let someone else deal with what may occur further down the road .
#25 |
another thing that could be damaged is the catalytic converter(s) or other parts of the emission system that would lead to poor performance , such as rough idle ,etc..
#26 | |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
![]() Glad no one messed with it. That's got to be a weird feeling thinking you lost the keys. |
#27 |
Drives: Yaris Join Date: Dec 2008
I would not sweat it. The Yaris engine is bulletproof. 1.5 hours is nothing. Now if you left it idling for days until an dentire gas tank ran out, that might be one thing, but this engine is built for survival.
#28 |
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
i idle here and there when i want heat working on audio in the car... no issues here
Sold the yaris... rocking an 89 vw cabriolet now :) |
#29 |
Parallel Parking Pro
You guys are amazingly anal about the car. Heat may build up at idle but its winter over there. Its probably less stressful on the engine to be at 0mph and idling at 600rpm for two hours than to be sitting on 70mph and 3500rpm. Remember, the engine still has a thermal fan that turns on when water temps get too high. It takes care of itself; you only need to keep it fed with fuel and serviced regularly.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#30 |
![]() Drives: 2008 Hyundai Accent SE Join Date: Oct 2008
Probably overheated and burned out your cataylitic converter.
#31 |
Audio Junky
I've ran my car has ran for 5 hrs at a time.... but when driving a constant 70mph....
I don't understand how idling for 1/3 the time can be any where near the wear & tear that driving highway speeds is. It is all in your head. |
#32 |
#33 |
when you drive at highway speeds the water pump circulates the coolant throughout the engine block faster that then passes into the radiator which cools the coolant that then recylces picking up the heat caused by friction within your engine . The wind that passes around your engine helps cool as well . When idling , this is not possibly ( relies on the fan ) . This is why it's mentioned in owners manual to change oil sooner if stop and go driving or when towing , called SEVERE CONDITIONS . Beileve me I've learned by experience . Heavily relied on cars for our income . CHANGE THE OIL SOON AS POSSIBLE .
#34 |
Don't waste your money, you DON'T need an oil change...
#35 |
About 5 hours on a trip to Tennessee
#36 |
![]() ![]() ![]() Drives: Black Yaris YRS 3dr Manual Join Date: Aug 2007
Fifth gear showed on one of their eps the testing a ford focus ST goes through. It was 100000miles at full throttle (6000rpm)
i think 1.5hrs idling is not going to kill the yaris hehe |
| retrofit time as soon as I get my yaris | birdy | General Yaris / Vitz Discussion | 15 | 05-02-2006 05:46 PM |
| engine modify Yaris D-4D | uraz | Performance Modifications | 10 | 04-30-2006 11:53 AM |
