![]() ![]() ![]() Drives: 08 sedan at Join Date: Dec 2008
Dealer overflows engine oil by like one quart..........
do these guys even check how much oil they put in?
on a flat surface, after overnight, i check the engine oil it's like one inch OVER the high "dot" what should i do |
the yaris takes 3.75QT of oil. Royal Purple is sold in 0.965(?) quarts, anyways, it adds up to something around 3.8QT when filled with 4 bottles.
the dip stick does go pretty well over the "high" dot over night. I will check it again tomorrow morning... |
so there's no accurate way of checking it?
#4 | |
![]() ![]() Drives: 07 BB Yaris Join Date: Aug 2007
I usually just add 4 quarts and it ends up being just over the full mark with a new oil filter. |
Drives: 2009 Yaris liftback Join Date: Nov 2008
I just did an oil change and can tell you that it should take around 3.5 quarts.
![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
I put four quarts and that puts it just over. Never bothered to check after a dealer change.
#7 | |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
+1
Ain't gettin' any younger .
or go to PEPBOYS , AUTOZONE , ADVANCE AUTO PARTS , or WALLY WORLD and get the 5 quarts of oil and filter for $15.99 or less and D.I.Y.. Here's some specials , http://www.bobistheoilguy.com/forums...oard=33&page=1 . That's if you have the place , tools , and knowledge to do it . GOOD LUCK
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I would take it back. Tell the service manager that trust in their dealership for future service work is broken. If you play your cards right you might get the next oil change free. Your experience is why I do all my own service work.
Making a decision without following it with an action is still a fantasy. |
#10 | |
so far i have driven like 350 miles since the over oil change, bad bad bad? |
I let mine drain for a while and use about 3.8 quarts and its perfectly to the full mark or a little below. I think they dont let it drain enough and then they add the 4 quarts.
#12 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
+1 , get it done soon as possible . Being so full could harm seals , gaskets , and seep past the rings due to extra pressure within the motor affecting emmision system .
#14 |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Join Date: Oct 2008
+2 Plus if you take it back in and there's any damage incurred later as a result of their negligence, you got it on record. Word.
#15 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
I have yet to find a dealer that isn't sloppy about their oil changes. Two Jeeps I have that get dealer oil changes are always overfilled. I have to take them home and loosen the drain plug and bleed off the extra till it's back to the full mark. Last time they dumped oil all over the motor and it ran down the back side-very smelly for a week no matter how much I tried to clean it off. This car has never seen a dealer yet-I do my own oil changes since it's simple and there are no grease fittings to worry about. If you don't have the place or means to bleed it off yourself-try taking it back to the place that did it. As already stated here, it is not good for the engine/seals. Good luck.
| leaky seal on engine? oil overfill? | jeff69dini | DIY / Maintenance / Service | 23 | 06-07-2010 12:52 AM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
| don't think the dealer changed oil filter on first change | gonzo452001 | DIY / Maintenance / Service | 0 | 01-13-2007 11:44 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
