Old 12-30-2008, 10:03 AM   #1
rizaydog
rizaydog's Avatar
Drives: 2016 5 Door Yaris
What is this?
I have a 2008 auto sedan. I was cleaning it this weekend and notice two things I don't know what they are. The first in attached to the black trim around the bottom of my shifter. It looks like a button. I pushed and pulled but nothing happened. I popped it off and there is some type of button underneath. Any ideas.
The other thing is on the lights above the rear view mirror. It looks like slits in the plastic. Is it for heat distribution?
rizaydog is offline   Reply With Quote
Old 12-30-2008, 10:08 AM   #2
any pic of the first one? I'm not quite sure what you are referring to.
As for the second, it is believed to be for a microphone, as the Yaris in some countries comes with a built-in Bluetooth speakerphone. I think it might also be used, in other countries again, for the automatic climate control.
Old 12-30-2008, 10:28 AM   #3
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
The first one is an emergency button to move the shifter out of park or possibly to move it if its stuck in any position. I had to use it once when I couldnt shift it out of park when I had a blown fuse. You hold it down and the shifter should move freely without having to step on the brake.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 12-30-2008, 12:12 PM   #4
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Dang, I was going to say it was the ejector seat button but Eii got to an answer first (which I agree with).
Old 12-30-2008, 01:57 PM   #5
rizaydog
rizaydog's Avatar
Thanks alot. Thats good to know.
