![]() Drives: 2008 Yaris liftback Red Join Date: Dec 2008
I get a rymthic hum at about 72-75 MPH?
I have noticed this after the break in period. (kept it slow for break in) I get a very rymthic hum at a little over 70 MPH. every 2 seconds or so..on then off. sounds like it is coming from the front somewhere. hasn't really bothered me a ton i have rebalanced the tires & rotated & also replaced the wheels, (not for this but to get away from the hubcaps). i can only hear it when the radio is off. very light sound. just wondering if anyone has the same sound. I now have 13,000 miles & it has never been to the dealer. i have done all my own maintance.,, 1,000 mi oil...3,000oil...5,000 syn oil... 10,000 syn oil. checked trans fluid properly.
![]() ![]() Drives: 07 BB Yaris Join Date: Aug 2007
You will hear many noises coming from somewhere in the Yaris. I get a whine/hum at about 40mph.
Sleep well at night, as you have a 3 year/36 month warranty. If it gets worse, take it to the dealer. The noise is probably normal. The hum/whine still remains a mystery though. I wish I knew what it is. VVT? solenoid? rotational frequency of transaxle? or engine (not likely)? |
#3 | |
![]() ![]() ![]() Drives: 08 sedan at Join Date: Dec 2008
yeah it isn't that loud, I kinda figured it was fairly normal. and actually I have the 100K Toyota extended warranty, so I was not too worried. just wondering if people had similar noises. love the forum. it helped me do the TRD lowering springs in about 2 hours, I need to get a picture up
actually.. mine became more noticeable ever since i got a control arm/table changed. And mine has a part that is out of spec, and that cannot be adjusted in the alignment.
manual or automatic?
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
Mine hums at 35-40 mph...
I know its probably the tires though. |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Get that too past 60 MPH. Always thought it just road noise
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
I get it too 60-65 and up. I had a car a few years ago it came with cheap tires which had the same kind of hum, I changed them to a better tire and the hum went away. I want to change the tires soon on my car anyway they are already wearing, maybe it will help?
http://www.midatlanticnostalgiaconvention.com |
Its our tires. If you have the factory bridgestones the only way to get rid of that road noise is to replace the tires. But dont worry they have a treadwear of a mear 160. So that will happen very soon. Even with proper rotation the max life you will get is maybe 2 years.
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
mine has a pulsating light hum at 55-65 and when i let off the gas it stops.. did it the day i bought it and has done it ever since.. everything works fine and havent had any issues.. if there is an issue.. the dealer will hear about it
Sold the yaris... rocking an 89 vw cabriolet now :) |
![]() ![]() Drives: 2007 Yaris Sedan Aero Join Date: Mar 2007
I get that noise also. Thought it was my aftermarket 17" tires, but the 14" snows do it also. So I assume it isn't tire related.
![]() ![]() Drives: 08 Polar white hatch Join Date: Oct 2008
The yaris has no sound deadning. The pronounced road noise and that hun at aroung 65-75 is allways going to be there unless you put in a lot of dynomax.
#14 | |
| RPM at 60 mph 5 speed manual | mark schofield | DIY / Maintenance / Service | 13 | 10-08-2011 12:14 AM |
| 17" rims and fuel economy | songa | Fuel Economy Forum | 27 | 12-20-2008 11:44 PM |
| MUST READ!!! MPH to RPM to Time ratios,gas savings! | eco | Off-topic / Other Cars / Everything else Discussions | 13 | 09-30-2007 02:00 PM |
