Old 09-06-2006, 12:55 PM   #19
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
i could tell you if it fit if you post a engine bay pic.
because honestly i dont see toyota wasting money making two sepperat engines, rather just one the 1.3, and displacing it to a 1.5.
but post a pic to confirm anyway.
Two Yari on home!
thewifesyaris is offline
Old 09-06-2006, 02:33 PM   #20
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Ok.Here is a picture
Katana is offline
Old 09-06-2006, 02:34 PM   #21
Katana
Katana's Avatar
And another one.Imagine it without the blue tube
Katana is offline
Old 09-06-2006, 06:30 PM   #22
RossP
Drives: MK I Vitz 1.0l F Package
No, the 1.5 engine is a 1NZ-FE, your one the mounting point for the filter is on the top of the engine block
RossP is offline
Old 09-06-2006, 08:03 PM   #23
thewifesyaris
it might work... you might have to work with the intake for a while, i could add some extra straight pieces which might help the fit.
Two Yari on home!
Old 09-07-2006, 05:15 AM   #24
Katana
Katana's Avatar
Does it have any adapter for the AFM?
We just have to make sure that it will fit, with the necessary adjustments!
Katana is offline
Old 09-07-2006, 01:17 PM   #25
thewifesyaris
afm?
Two Yari on home!
Old 09-07-2006, 01:38 PM   #26
Katana
Katana's Avatar
Oh it is a device after the air filter box, that ''reads'' the incoming air quantity and with the help of the central chip adjusts the engine function.
Your engine should have this.
Katana is offline
Old 09-07-2006, 01:45 PM   #27
LBdriver
Drives: 07 yaris MT
I don't know why you would try to sell a intake that does not work well in the yaris.
Yes it makes it loud if you can keep the engine running.
I tried a set-up just like that, made from the exact the same pieces and it did not work.
I wasted more than $80.00 just to try it.
The car would not idle correctly and when I gave it a little gas it would just die.
Most intakes made for the 1.5 are closer to a 2" diameter. The 3" diameter does not work well with the 1.5l.
Maybe it did work for you but doubt it.
I just took the loss and tossed the pieces.
LBdriver is offline
Old 09-07-2006, 02:01 PM   #28
ChinoCharles
Drives: LB
Bummer man
ChinoCharles is offline
Old 09-07-2006, 06:22 PM   #29
thewifesyaris
worked fine with the wifes she had no problems with it, she only complained once and I explained to her that it was only because the car had not fully warmed up enough.
you might have ran to big of a filter, i chose the smallest most restrictive, so that there would be suction created verses too much air for the MAF sensor to notice. It was a bit bumpy at first but her ECU learned to drive with it after about two weeks. Did you try resetting your ECU after install?
the major reason Im selling it is that she complained it was too loud. So i promised her that i would get her another made of smaller tubing to reduce resonation. so we bought the silver AEM CAI, she wants it for her birthday so its not going to be installed until november, and she wont let me open it because she paid more for it than I did, so dont ridicule and flame me for no pics just yet. But after hearing the sound clip for the TRD CAI i think she might end up not liking this one either.
Two Yari on home!
Old 09-08-2006, 06:57 PM   #30
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Thats called the MAF Sensor my friend... As in Mass Air Flow sensor.
Chris07LB is offline
Old 09-09-2006, 02:51 AM   #31
Katana
Katana's Avatar
Chris I am kind of pretty sure about it.
AFM= Air Fuel Meter.
In any case, we are talking about the same thing here.
Katana is offline
Old 12-04-2008, 08:11 PM   #32
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
does it fit a sedan?
msfire671 is offline
Old 12-04-2008, 08:21 PM   #33
3" diameter?
i went to use a 2.5" diameter intake from my xrs and it didnt work...threw system lean codes
stock 1nzfe intake tubing is 2.25"....thats what the maf is set up for
frankly, im surprised that intake runs w/o cel's, funny idle, or odd power peaks mid-range.....
thebarber is offline
Old 01-17-2009, 11:07 AM   #34
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Pretty Positive its MAF. Not to bust anyone's b*lls of course, just to clarify
From Yaris Repair manual Engine control page ES-1
AlexNet0 is offline
Old 01-17-2009, 01:02 PM   #35
thewifesyaris
Holy dragged up dead post batman!!!!!
Two Yari on home!
Old 01-17-2009, 08:48 PM   #36
AlexNet0
AlexNet0's Avatar
oops
AlexNet0 is offline
AEM INTAKE ***UPDATE*** riceboy Performance Modifications 30 09-10-2007 07:35 PM
Air selection intake broken? David81 General Yaris / Vitz Discussion 16 06-29-2006 02:51 PM
K&N Is looking for 2007 Yaris for Intake Development. Knfilters Performance Modifications 9 06-28-2006 04:34 PM
K&N Developing intake mykole Performance Modifications 9 06-22-2006 01:34 AM
Cold Air Intake ? pegcityrs Performance Modifications 47 04-17-2006 07:43 AM
