Old 02-02-2009, 09:42 PM   #163
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
ok buddy so answer me this
1.where does the electricity come from for your power steering on the yaris? thin air? no... it comes from the battery, and the battery is charged by the alternator. power is power lol
2. if you're "driving in a straight line" how much power is being consumed, electric to hydraulic?
3. did you ever consider gear ratios could be the reason the yaris gets better economy?
1) Battery can be charged even when you're idling. Charged energy can then be used to steer. Without using battery, you need to get all power from the engine power at the time of steer. Power is power, but power can be saved instead of wasted.
2) It's true. This concept doesn't do any good for straight line.
3) Yes, gear ratio can make A LOT more difference that steering system. I just mentioned steering system because it just came to my mind at that time. There are so many things that can make difference and steering system was one thing, which probably is one of the smallest :(
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 02-02-2009, 11:11 PM   #164
Morgan
Morgan's Avatar
Drives: 07 MM LB
Originally Posted by tetzyamis View Post
...3) Yes, gear ratio can make A LOT more difference that steering system. I just mentioned steering system because it just came to my mind at that time. There are so many things that can make difference and steering system was one thing, which probably is one of the smallest :(
umm you do realize he was referring to the transmission, right?
Old 02-03-2009, 03:13 AM   #165
tetzyamis
'09 5dr
tetzyamis's Avatar
I can't think of anything else in the car that has a gear ratio other than transmission...
Is there anything else?
All I wanted to do was just to add one more difference between Yaris and xA since Tamago was listing down the differences and power steering system wasn't there.
If the gear ratio is different, then that's just another difference.
Old 02-03-2009, 07:54 AM   #166
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
my gears are shorter, which means my car = faster off the line ;)
oh and your other gear ratio is your rack and pinion ratio.
Originally Posted by xnamerxx
you nailed it sir.
Old 02-03-2009, 04:15 PM   #167
tetzyamis
'09 5dr
tetzyamis's Avatar
Oh, I see!!!
No wonder Morgan asked that since we were talking about steering.
Everything makes sense now
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 04:59 PM
GROUP BUY ZETA PRODUCTS YARIS LIFTBACK ARMREST zetaproducts.net Sponsors Classifieds Area 29 11-13-2008 01:37 PM
