Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Removing Door Panels - Hatchback?
Anyone here have workbook instructions or can instruct me on how to remove the door panels on the liftback/hatchback?
TIA
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
Look mum no stars!!
Easy, i was about to make one....but i couldnt be fucked......lol.....
Well this is a simple version of it. If you know a little bit about cars then this simple tutorial will be NP.. >Pull out the 3 grey long strips on the door >If you have power windows, on the DRIVERS side the switches for the power windows will have 3 screws that will be attached to the grey plastic thing. Take them out >So the 3 grey plastic things should all be deattached. >Next there will be 3 black screws attached to the door panel.....take them out, one is in the middle and i forgot where the others are. But there are 3! >time to pull it off! Pull the bottom part of the panel, and it will pop out. (Only the bottom half will pop out) >Next is to PULL UP the door panel and the whole thing should come out. Hope that helps
Because I don't want to start a new thread, what has to be done to change the front speakers?
#4 | |
Look mum no stars!!
THE PROPER WAY >take out the wire plug thats connected to the stocked one... >Get a DRILL and DRILL OUT the rivets that is rivetted on....(the silver things) theres 3 >get the "SAT6" bracket/spacer and attach ur 6.5" speaker onto it ![]() >attach the wires to the new speakers to the wires onto the door. Negative with Negative and Positive with Positive. >Time to screw the new speakers on, u can either screw it on or rivet gun it. THE LAZY WAY >take out plug which is connected to the stocked speakers >LEAVE THE STOCKED BRACKET/SPACER in the door BUT RIP OUT the speaker (the middle part dont damage the stocked spacer) >mount your new speakers on the spacer on the door, connect the wires, and screw in your speakers with screws to the stocked spacer.
Τhanks mate for the answer!
Always there for any questions!
Look mum no stars!!
U know what, u should do it the lazy way....i did it the lazy way and i have no probs!!!
The difficult way isn't more safe for damages?
Look mum no stars!!
haha i believe that both ways are the same....its just changing the spacer. the lazy way is just a really really cleaner and quicker way of doing it. I have dont it and i had no problems with it. Still going strong.
Ok thanks man!
Cousin Vitz
Thanks hasher!
Will post pics of my install when the time comes to give the visuals for the above instructions.
Look mum no stars!!
Ahh nice...though i already took pics for a tutorial....but i really couldnt be bothered uploadin it...ha
Cousin Vitz
Upload them mate!!!
Come on, we need one of your great tutorials!
#14 |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
What about the rear speakers, 5.25 speakers, right? do you need different spacers or will the SAT6's work back there too?
#15 |
Look mum no stars!!
Katana...i seriously cant be bothered...lol
paul i was able to install the rear speakers......but they arnt install prop. I really dont know if the "sat6's" will fit in the rear... Does anyone know if the sat6's will fit in the rear guys???
#16 |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Aug 2007
This might be a dumb/lazy question...but here goes...
which wire is positive and which one is negative. Is it in the manual or where/how did you find out? Thanks |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
i need to destroy the speakers for remove them from the stock brackets???
#18 |
![]() Drives: 2007 Yaris Join Date: May 2010
I can't get my hatch panel off to install an actuator. Does anyone know if there's a screw somewhere in it that I'm missing?? Thanks!
| 3 Door Hatchback Questions | Dorkinheimer | General Yaris / Vitz Discussion | 12 | 01-16-2012 05:30 PM |
| Removing sedan mirror covers? | Spades | Cosmetic Modifications (Exterior/Interior) | 6 | 01-12-2012 09:10 PM |
| Just Bought a 2009 Yaris Hatchback 4 Cyl Auto!! CASH DEAL!! Good Deal?????? | paguy | General Yaris / Vitz Discussion | 13 | 05-28-2009 10:51 AM |
| Do any other Toyota front seats have same bolt pattern as Yaris? | ScottFern | DIY / Maintenance / Service | 18 | 07-02-2007 11:44 AM |
| Yaris Hatchback Clearance Height | Ryu | General Yaris / Vitz Discussion | 7 | 11-28-2006 01:35 AM |
