Old 02-06-2009, 10:48 AM   #343
Rudysin507
Drives: Yaris HB 2005
Now this is my question.... is there any of those pulleys available for the 1st generation Yaris or Echo (whatever makes you happy)? we have a small crew down in Panama city, Panama very interested on that but we are not sure if we get them, are they going to fit or to work in our engines? 1.3L 2nz-fe
Rudysin507 is offline   Reply With Quote
Old 02-07-2009, 02:32 PM   #344
NonStopTuning
Originally Posted by CtrlAltDefeat View Post
... and now I've had a few days with a properly working car and I really only have one word for the underdrive pulley...
WOW!
It's hard to believe one little upgrade could make such a difference... It revs better, accelerates faster, even sounds nicer, I think. One thing I know, the shift points have moved. With the stock pulley, shifting into 2nd happened at 30mph and shifting into 3rd at 60mph. It's changed to 33-34mph and 63-64mph respectively. And getting to those shift points is much quicker. In stock form hitting 85mph was like an event. (that's my video btw) Now I find myself pulling it back from 80 all the time... I down shift to pass someone, and suddenly I'm on my way towards 90... To tell the truth, with stock suspension I think it's almost a little scary! I took my coworkers to lunch yesterday, and thought it was kinda funny to watch their heads snap backwards. I think I'm going to take another 0-85 video when I get a chance and post it here...(maybe after my springs are installed) In closing I must say
NST FTW!
Glad you are enjoying your pulley!!!
MIKE @ NST
www.NonStopTuning.com
Old 02-07-2009, 02:35 PM   #345
NonStopTuning
Yes, these same pulleys fit the 1.3L. Many international Yaris owners are using these pulleys.
Good luck and have fun with all your projects down there
MIKE @ NST
Old 02-07-2009, 04:38 PM   #346
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
My 3rd gen yaris is running a 2nz-fe and i an running all the NST pullies
and they are great.
Old 02-07-2009, 08:25 PM   #347
kimo
kimo's Avatar
Drives: Honds City 2005
Whats is the diffrence in performance between the light CR and the 10% under light CR pulley.
kimo is offline   Reply With Quote
Old 02-08-2009, 11:54 PM   #348
NonStopTuning
CR-Lite can be used in n/a, turbo, and supercharged applications.
Underdrive Crank Pulley is designed for n/a, and turbo, and will free more power for these applications.
MIKE @ NST
Old 02-09-2009, 11:06 AM   #349
Rudysin507
Thumbs up all right then!!!
Thank you guys! it looks like i have a new project to work on!! looking forward to see results.
Old 02-09-2009, 11:00 PM   #350
auxmike
auxmike's Avatar
Can these things endure years of roadsalt from nasty NE winters?
Old 02-09-2009, 11:07 PM   #351
supmet
Drives: 2007 4 Door Yaris
I'd think anodized aluminum would handle it better.
You might wanna check on something else if you are getting salt that far up into your engine compartment though :D
Old 02-10-2009, 12:41 AM   #352
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
You should not have a problem at all ,
as i have use anodized pullies for years on boat -anchor whinches
Old 02-10-2009, 07:48 PM   #353
whiteghetto
whiteghetto's Avatar
Drives: '07 blazing blue hatch
wow, way to much info here.
But I don't think this question has been answered
I can either get the light crank pulley or they 2 pulley set from cali yaris.
what would yeild more benefits?
2007 LB w/CAI. and a small sub amp (about 600 watts)
Will also be getting a rear sway bar, just want to know what pulley to order :)
any help or info is greatly appreciated
2007 HB Blazing Blue
whiteghetto is offline   Reply With Quote
Old 02-10-2009, 10:23 PM   #354
NonStopTuning
I will copy and paste the answer I gave you via Email earlier tonight...
I have a, hopefully, pretty straigtforward question.
I am wanting to know what setup would provide better results in MPG and HP
1) crank light pulley(NST09010)
2) Pulley Combo (NST09025K)
My car in a nutshell
2007 Yaris LB w/auto w/CAI w/600 watt sub amp
thanks for the info :)
John
Hi John,
Thank you for your interest in our site and products, we appreciate it.
The setup that would provide the best results in MPG, HP, TQ, and throttle
response would be one that would provide the MOST weight reduction along with a
small amount of underdriving of the accessories.
So you should consider NST09010 Underdrive Crank Pulley + NST09025K Alternator
and Water Pump Pulley Kit. The more NST pulleys, the better the overall result.
Thanks again, and good luck!
MIKE @ NST
Old 02-10-2009, 11:41 PM   #355
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Hold your horses guys!!!
The 1.5L and the 1.3L pulleys are the same as long as they are the same generation Yaris.
For the first generation Yaris (echo) either the 1.5 or the 1.3 you need to look for the Scion xB (first gen) pulleys.
Your cars have a double belt design crank pulley that is not a match with the Yaris pulleys offered by NST.
However, don't feel bad... NST has pulleys for the first gen xB that should fit your cars!
Old 02-10-2009, 11:53 PM   #356
NonStopTuning
I don't know how many times I have had to type this same thing in this same thread
International customers with TWO-ROW crank pulleys in their cars need to order from our xA/xB page...
http://www.nonstoptuning.com/pKitToySciXAXB.htm
The majority of the rest with SINGLE-ROW crank pulleys can order from our Yaris page...
http://www.nonstoptuning.com/pKitToyYaris.htm
No doubt we will be discussing this again in a few pages
MIKE @ NST
Old 02-13-2009, 02:50 PM   #357
NonStopTuning
Anyone else?
MIKE @ NST
Old 02-24-2009, 07:00 PM   #358
xen555
xen555's Avatar
Drives: 3 DOORS LB
Anyone else?
yeaah yeahh mee!!!
im ready to make an order for my little red one!!!
how long take the shipping to puerto rico in your experience??
im very anxious for one of those pulleys!!!
xen555 is offline   Reply With Quote
Old 02-24-2009, 11:19 PM   #359
NonStopTuning
Originally Posted by xen555 View Post
yeaah yeahh mee!!!
Shipping to PR is the same as any US state via USPS Priority Mail. 2-3 day service for only about $10.
You can place your order with us on our website whenever you're ready
MIKE @ NST
Old 02-25-2009, 09:59 AM   #360
xen555
xen555's Avatar
Drives: 3 DOORS LB
i did it last night!!!
ps: i dont remeber if i specified the color... i want the red !!! thanks
