Lightweight battery install
Well, I did some research and came up with what is pictured here. Battery is a Deka EXT20L from East Penn Manufacturing which is also labeled as Big Crank, another which I shall not name and more. Cost for this model (15lb) was 69.95 shipped. Procured the tray (aluminum), modified it somewhat and secured it to the factory tray using one of the trays original bolts and added 1 grade 8 hex bolt/nut & washer. Fabbed the cross bar hold down out of aluminum stock and managed to find a suitable means to secure my stock hood prop. Final addition will be to wire for plug in Battery tender.
Update: No need to wire for tender. Our lighter plug is hot with key off so a plug in adapter for the Battery Tender is on its way. Bingo Last edited by Klink10; 02-15-2009 at 06:34 PM. Reason: Update added |
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
Looking sharp!
Very clean installation. ![]() I like how you keep your engine compartment surgically clean.
Benggolf2 |
Thanks
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Very nice setup.
#5 | |
Where did you get it for $69.95? I only found a link for $115.
Tri State Battery......$69.95 shipped. Deka EXT20L
http://www.tristatebattery.com/produ...roducts_id=981 Thanks for looking, I will be glad to take it apart for pics if anyone wants further install answers. |
Audio Junky
I'm thinking SOOO hard about buying one of these after I finish the stereo.. OHHH. I'm just afraid the stereo will be too much. I will only have 500rms (to my front speakers, 3 way components) no subs... but still... 500rms might be a bit much without a battery with a good reserve. Good thing I got a manual.. can always push start I guess.
Update again....Well I found out that our cig. lighter is not hot when the car is off. No problem....I am wired now with Deltran's fuzed wiring accessory that remians fastened to the battery. My shop was wired with a seperate receptacle for plugging in the Battery Tender Jr. that operates on its own switch. Now when I park the car I just open the hood, grab the lead plug it into the tender lead and flip the switch. Works like a champ. Pics if wanted.
Dude. That velcro on the strut bar for the hood prop is WAAAY Pro. I likey.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
Thanks
Curious - what does the stock battery weigh?
32 lbs.
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| battery power question | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 22 | 12-05-2008 08:37 PM |
| where can i install these power locks? | songa | New England | 1 | 12-04-2008 12:41 PM |
| 6lb 6oz ultra light weight battery | heavystarch | Performance Modifications | 28 | 11-19-2008 06:02 PM |
