Old 02-24-2009, 09:27 PM   #19
500snakz
500snakz's Avatar
Drives: 08 Polar white hatch
Plain and simple...the yaris is designed to run on 87 octane gas(REG) and running 93(premium) yes we have 93 here, could actually cause poor performance and may actually damage your motor. Read your owners manual and use the recomended fuel type. MORE is not allways better. I would just stick to the book and make sure the dealer dont have an excuse to void my waranty.
500snakz is offline
Old 02-25-2009, 09:56 AM   #20
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
yeah my dealer just got that new fuel grade machine where they test your gas to see if your running what the factory says.....
BLAZINBLUEVITZ is offline
Old 02-26-2009, 12:31 AM   #21
jkuchta
Drives: 2007 Yaris hatch (red)
The octane specified in the owner's manual is a MINIMUM requirement, not a recommended octane rating. Your warrenty will NOT be voided by running higher test fuel.
I see higher ignition advance under all conditions (via scangauge) with 91 than I do with regular, which tells me that the car is actually taking advantage of the higher octane. The people that mention their warranties being voided on this forum would do well to learn about octane ratings and meanings.
jkuchta is offline
Old 02-26-2009, 01:01 AM   #22
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
and does your scangauge pat you on the back and say 'omg bro, check out your newly found power!!' ?
Originally Posted by xnamerxx
you nailed it sir.
Tamago is offline
Old 02-26-2009, 09:39 AM   #23
Castaway
Drives: 2008 Yaris hb 2d
Wikipedia: The octane rating is a measure of the resistance of gasoline and other fuels to detonation (engine knocking) in spark-ignition internal combustion engines. High-performance engines typically have higher compression ratios and are therefore more prone to detonation, so they require higher octane fuel. A lower-performance engine will not generally perform better with high-octane fuel, since the compression ratio is fixed by the engine design.
Castaway is offline
Old 02-26-2009, 09:54 AM   #24
ChinoCharles
Drives: LB
I'm going to go ahead and close this one up guys. I think the OP's question was answered sufficiently. Another job well done, YWers.
ChinoCharles is offline
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
Facts of Higher Fuel Octane Yaris TTE JWRC General Yaris / Vitz Discussion 9 01-29-2007 08:16 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 08:17 PM
What octane fuel is recommended? sroberts General Yaris / Vitz Discussion 4 06-09-2006 09:54 PM
