I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
Factory Stereo and Amplifier - can I do this?
Title says it all. But I want to keep my stock head unit and add an amplifier. Can this be done?
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
![]() ![]() ![]() ![]() Drives: 2007 Yaris S Join Date: May 2006
yes, but you will need a line out converter, or an amp that accepts high level inputs
I drive a yarrrris
ummm, any links with more info so I can read up on it?
fyi; thanks.
I drive a yarrrris
sorry i was just being lazy.... i know i know its called google. thanks again.
http://www.sonicelectronix.com/cat_i...onverters.html is a bunch of line out converters
and http://www.sonicelectronix.com/searc...=Search+Now%21 a bunch of high lvl/speaker lvl input amps |
I drive a yarrrris
Thanks for the links, I'm gonna go with a line-out converter and am currently looking at amps now.
edit: Going for amp that excepts high lv inputs.
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts Last edited by vodkalush; 09-18-2006 at 02:44 PM. |
#7 | |
MPG is the new cool
-Peter
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US) Join Date: Sep 2006
why bother with a special amp, line out converters are like 25 at most
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
I'm doing this very thing. Stock HU and main speakers for now, and just installing an amp and 1 12" sub in a small box.
Once I get my flip up Monitor HU I'll install componets in the front, and 2 ways in the back. Lucky for my my JBL amp has high level inputs already. I'll just run my remote on switch from the sig lighter for now scratch that, just read in the owners manual no remote on wire is needed if using high level inputs with my amp. Sweet. Just need to find an sub now
The early bird gets the worm, but the second mouse gets the cheese. Last edited by 07WYarisRS; 09-19-2006 at 02:16 AM. |
I drive a yarrrris
http://www.pioneerelectronics.com/pn...568903,00.html
![]() the one I'm getting, nothing to fancy just somthing to give a lil more umph to my new speakers.
![]() Drives: 2007 Nautical Blue Yaris Sedan Join Date: Sep 2006
Keep us up to date.
I would like to add just a little bit of bass to my car. Nothing fancy just enough for ME without annoying other drivers. If I use converters to change my rear speaker outputs into RCAs, wouldn't I then need an amp for my rear speakers and another amp for a sub? Anyone know of an amp with enough channels to do this all in one? |
HardlyDangerous
I'm running a JBL BP 300.1 amp. 300W @2 ohm or 1ohm, 150W @ 4ohm, it has low level RCA inputs as well as front and rear L/R high level inputs.
Any amp with high level inputs will work with no need to buy anything. All you do is splice into the signal wires to the speakers and run them to the amp. If you don't have high level inputs on your amp (only low level RCA) you just buy a hi-low convertor, and wire it the same way into the cars speakers then plug the RCA's into the amp. No need to run an amp to the rest of the cars speakers if you don't want to at this time. This works out pretty decent in most cases because it allows you to turn down the bass to the main speakers for better sound and less distortion, and allows you to adjust the bass with the amp/sub.
The early bird gets the worm, but the second mouse gets the cheese. |
Holy crap you guys buy a lot of Pioneer.
#14 | |
I drive a yarrrris
i'm trying to keep all the logo's the same
#15 | |
HardlyDangerous
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
I just reallized, every single amp I've ever owned had high level inputs! What cheapo amps are out there that don't have them... I had a WalMart special that had em for cryin out loud (Dont judge, I was a very poor college student)
alot of times it is the cheaper ones that have them ;)
#18 | |
