Old 02-25-2009, 10:26 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
How do I tap into the light dimmer circuit?
I'm installing Autometer gauges and have found that the LED backlight illumination is too bright at night. Does anyone know where to tap into the dimmer-controlled circuit?
My friends and I are guessing that the car uses pulse width modulation to dim all the illumination LEDs throughout the dash and AT shift console. Autometer sells a little box that will dim their meters but I'd rather control the light output from the factory dimmer switch.
Thanks
Old 02-26-2009, 12:19 AM   #2
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Do you usually dim your regular dash lights with that dimmer? If you don't, then you might run the risk of having your dash lights too low so that your new gauges are comfortable. Just a thought...!
Oh, and I still owe you logos!
2006 Red Blitzed RS 5-door
Old 02-26-2009, 12:33 AM   #3
LtNoogie
LtNoogie's Avatar
Yeah, who needs to add blue LED interior lighting when you've got the C2 gauges at full brightness. I probably look like a smurf to people outside the car.
Old 02-26-2009, 12:47 AM   #4
I'm at work right now and not able to look up the wiring diagram, but I can confirm that it uses a PWM dimming system (look at some of the night-time videos I took, the gauge cluster is flickering because of the lack of sync with the camera's refresh rate )
Old 02-26-2009, 12:53 AM   #5
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
subscribed
Old 02-26-2009, 01:25 AM   #6
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
when my friend and i wired up my tach the other weekend, we took everything from the dimmer circuit but for some reason, when we went to dim the tach light the needle went wild. we then took power from a different source and i am a little sad to say i cannot vary the intensity of the gauge light.
Wanted: Forced Induction
Old 02-26-2009, 01:40 AM   #7
LtNoogie
LtNoogie's Avatar
I don't know your tach but it sounds like you ran the +12V for the electronics into the dimmer circuit. The electronics need a solid 12V. There should have been a second wire that went to the dimmer circuit. How hard is it for you to reverse the wires?
Old 02-26-2009, 01:49 AM   #8
LtNoogie
LtNoogie's Avatar
Here are my choices if I cannot find a way to tap into the car's dimmer.
http://www.amazon.com/Universal-2-Ch.../dp/B001ES64MK
http://www.autometer.com/cat_accesso...l.aspx?vid=185
Old 02-26-2009, 01:50 AM   #9
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
not hard at all, however we tried that as well and came up with no success.
Old 02-26-2009, 02:18 AM   #10
The first one's pretty cool, 2 channels and you can mount it pretty much anywhere... Or you might get better value by using a computer fan speed controller, they run off 12V as well, and you'd get 4 channels!
Old 02-26-2009, 06:36 PM   #11
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You can go to Radio Shack and get a variable resistor or rheostat. It is much cheaper than the autometer solution.
You can then run the the gauges lights to the rheostat, and then to direct power and adjust the lights to you liking, or run the resistor to the interior lights.
If you do it that way you can adjust the new gauges to the brightness level you want them, and then adjust ALL dash lights as a whole. Just hide the rehostat under the dash.
You can find them at Radio Shack for a few bucks.
Old 02-26-2009, 11:43 PM   #12
Only the speedometer is dimmed using PWM. The light control rheostat has two 0-12 volt analog outputs that are supplies to the HVAC controls and to the combination meter. The beige wire is the dimmer feed to the HVAC knob lights.
If you pop the fuse panel compartment you can reach up and unclip the connector for the light control rheostat to get at its wires.
Old 02-26-2009, 11:49 PM   #13
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
a resistor for $.20 from radio shack would solve your problem :)
Originally Posted by xnamerxx
you nailed it sir.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 11:06 AM
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Dome Light dimmer carlosh Central and South America 24 07-27-2007 04:37 PM
