#19 |
![]() ![]() Drives: 08 Polar white hatch Join Date: Oct 2008
Plain and simple...the yaris is designed to run on 87 octane gas(REG) and running 93(premium) yes we have 93 here, could actually cause poor performance and may actually damage your motor. Read your owners manual and use the recomended fuel type. MORE is not allways better. I would just stick to the book and make sure the dealer dont have an excuse to void my waranty.
#20 | |
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#21 |
The octane specified in the owner's manual is a MINIMUM requirement, not a recommended octane rating. Your warrenty will NOT be voided by running higher test fuel.
I see higher ignition advance under all conditions (via scangauge) with 91 than I do with regular, which tells me that the car is actually taking advantage of the higher octane. The people that mention their warranties being voided on this forum would do well to learn about octane ratings and meanings. |
#22 | |
#23 |
Wikipedia: The octane rating is a measure of the resistance of gasoline and other fuels to detonation (engine knocking) in spark-ignition internal combustion engines. High-performance engines typically have higher compression ratios and are therefore more prone to detonation, so they require higher octane fuel. A lower-performance engine will not generally perform better with high-octane fuel, since the compression ratio is fixed by the engine design.
#24 |
I'm going to go ahead and close this one up guys. I think the OP's question was answered sufficiently. Another job well done, YWers.
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
| Facts of Higher Fuel Octane | Yaris TTE JWRC | General Yaris / Vitz Discussion | 9 | 01-29-2007 07:16 PM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
| What octane fuel is recommended? | sroberts | General Yaris / Vitz Discussion | 4 | 06-09-2006 08:54 PM |
