Old 03-08-2009, 08:14 PM   #19
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Originally Posted by clh333 View Post
Could I ask: which Yaris are you driving? I bought my 07 hatch from a dealer who has flatly refused to help me outfit it with fog lights.
If there is an OEM light stalk with a switch for fog lights that fits my column, I'd like to know what part number to order.
Thanks!
The part number for the stalk switch is 84140-52150 (06-08 hatch back) Price $96.17 list but can be bought at Sparks Toyota for $77.00
or if you have a 09 hatch back it is 84140-52151 not sure what the differrance is curently looking into it.
So be careful before you order one
Old 03-09-2009, 03:38 AM   #20
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Our 09 spec stalks look slightly different to the 06-08 ones.
Old 03-09-2009, 06:00 AM   #21
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
In what way , do you have a picture for us ,PLEASE
can't find any info on it anywhere , apart from the part number which i got from
another thread on here.
Old 03-09-2009, 06:17 AM   #22
spookz
JDM yO!
Well the headlamp stalk for the 06-08 Yaris (in Australia), has a twistable switch for 'rear fogs'.. while my 09 Yaris does not? This is comparing across the YRS grade we have in Australia.
Here we go:
The stalk in question:
and both stalks:
Edit - Added pictures
Old 03-10-2009, 11:17 PM   #23
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Back on track here, the P/N for the relay is: 90987-02012...
cm07yaris is offline   Reply With Quote
Old 03-10-2009, 11:43 PM   #24
That part number is listed for many other cars for various purposes, but not for the Yaris. The Yaris fog light relay part number is 90987-02027.
I am not sure what the difference is between the two, but I would check both with an ohm meter to see how they compare.
Looking at the bottom of the relay the terminals are arranged like this:
1 2
5-
3-
On the correct fog light relay:
1 to 2 is the coil and should read somewhere around 100ohms
3 to 5 are the contacts and should be open
1 to 3 and 1 to 5 should be open
2 to 3 and 2 to 5 should also be open
Old 03-11-2009, 01:28 AM   #25
cm07yaris
Thanks CTScott, in one of the other DIY guides it says to use part number: 90080-87026. Do you know anything about that one?
Old 03-11-2009, 05:21 AM   #26
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
The differance between the 2 relays is 1 is n/o normally open
the other n/c normally closed , this is the postion the relay sits before being activated ie n/o relay turn on your switch closes relay turning on lights
the relay you have installed at the moment is n/c so it will only turn your
lights on when it is receiving the signal from hi beam , which is the signal
that normally turns them off
if you need the correct relay talk to Gram at microimage as he has a few in stock .
Also the part number 90080-87026 is the only part number that returns as a part for toyota cost $66.67
but on sale at Sparks for $48.00+p&p
Or Garm can supply for about half that again.
Old 03-11-2009, 08:54 AM   #27
Thanks for the clarification on the relay specs 1NZ.
Also, 90080-87026 and 90987-02027 are the same part. Toyota revised the part number from the former to the latter.
Old 03-11-2009, 12:26 PM   #28
cm07yaris
Thanks again guys, I figured it had to be the relay!
Old 03-23-2009, 07:02 PM   #29
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I bought this relay a loooong time ago when the other thread was still around (with the DIY fog lights OEM style).
Was the relay the issue? If so, I will order the correct PN. For reference, I have the Denso relay 90987-02012.
devinlamothe is offline   Reply With Quote
Old 03-23-2009, 08:16 PM   #30
cm07yaris
I have tried 3-5 different relays, so I'm pretty sure it isn't a relay issue. Still trying to get to the bottom of it.
Old 03-28-2009, 11:19 PM   #31
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
here is a picture of the relay circuit
check it agaist your relay's
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Rear fog light for US '08 3Door Yaris (stick shift9 Stefan DIY / Maintenance / Service 21 04-21-2010 05:30 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 09:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 04:09 AM
