I love momentum.
Will a 15x6.5, ET40 with 195/50/15's fit?
I've found the wheel/tires I want for my Yaris (if I get it) and I was wondering if a 15x6.5 wheel (ET40) with 195/50/15 tires will fit properly. I don't want to put too much stress on the wheel bearings with the wrong offset, or rub any suspension components.
My plan is to keep the stock suspension for a while, then maybe lower it on TRD/Tanabe springs (and get a TRD sway). I want to build up the car for cornering (and commuting :D) Thanks all! |
15x6.5, ET40 will be just fine. 195/50's are far too short for your application. If you plan to lower on TRD's, then install 195/55's and you'll be just fine.
I love momentum.
Besides throwing off the speedometer, why would them being too short matter (I think it's a 9mm height difference)? If anything doesn't that buy me more space?
Who said Yaris was slow?
With TRD springs and 195 tires on that offset wheel you don't need more space. It will be just fine. If you go wider then you might have some rubbing.
IMO 55 profile tires will fill your fenders better and give you better look with the drop springs. If you don't have ABS, is not much of a problem. Your MPG might suffer a little as you will have a shorter ratio. If you have ABS, some say is better to stay within +/- 3% of the OEM tire diameter for safety. |
I love momentum.
Perfect. Thanks for the advice kimona/castrex!
195-50-15 is correct if you had 175-65-14's stock...
Schleppy, where are you in MA?
My set up gives me 3% off and it feels good! my MPG whent down a little bit , but who cares I'm still doing 36-39 mpg and feels a lot more powerfull and corners really good. Looks good to me, and rides 10 times better than stock with NF210s.You are more than welcome to try mine and feel the ride. .
. CLA 250, 4MATIC |
I love momentum.
I live on the north shore but I work in Woburn. I'd love to give your car a go sometime soon! Shoot me a PM with your details.
BTW, our speedos already have built-in error across models, so don't worry about that; it's insignificant.
My speedo reads 53 mph my GPS shows 50 mph
speedo 80 mph, GPS 75 mph
. CLA 250, 4MATIC Last edited by derickveliz2; 03-12-2009 at 09:45 AM. |
#12 | |
I live in Acton, work 2 days a week in Maynard and 3 days in Marlborough. Weekends I'm around; Maybe in our next Yaris Meet... Check out the pictures from last year... http://www.tabblo.com/studio/stories/view/1668622/ I'll send you PM with my info.
. CLA 250, 4MATIC |
aside from looking silly, i think you'll be fine with the above sizes..
#14 |
i have 204/40R17's under my Yaris... currently on stock suspension with no issue whatsoever!
#15 |
post your wheel width and offset too! :)
#16 |
![]() ![]() Drives: 2008 Yaris RS Join Date: Oct 2008
Formerly 2008 Yaris RS Liftback 5 doors: http://smg.photobucket.com/albums/v26/diofra/Yaris/ Now 2010 Matrix XR http://smg.photobucket.com/albums/v2...2010%20Matrix/ |
#17 | |
http://www.yarisworld.com/forums/showthread.php?t=5021 |
#18 |
![]() Drives: yaris sedan Join Date: Dec 2008
205/55/15 tires on stock wheels @ 15/5.5 ET 45, will i get any problems(rubbing, etc) with these? BTW, she's not lowered....
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 09:18 PM |
| Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd | Bounty Hunter | General Yaris / Vitz Discussion | 7 | 07-11-2007 07:40 AM |
