#37 |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Anyone could suggest me a quality oil pressure sensor to be used on the 1NZFE?
The sensor must be compatable with the G-TECH PRO EGS gauge http://www.gtechpro.com/egs.html |
#38 |
Since no suggestions were posted I decided to go with the R-spec High precision pressure sensor http://www.rspec.co.uk/index.php?mai...roducts_id=487
During a discussion with my electrical manager on the car engine management he said that the stock ecu is needed for basic activity like radiator fan power on, dashboard tach and fuel pump power on. So my question is, could the stock ecu interfere with the upgraded ecu in any means? Wiring is expected to be ready by tommorrow |
#39 | |
As for the sensor, did you email G Tech Pro for what sensor would be compatible?
#40 |
UPDATE:
Wiring about to finish. It only remains the high tension and then we go! BOV and coil pack installed! A turbo shield was installed aswell to prevent brake lines and other main wiring overheating BTW I am told that the 1NZFE internal springs are compatable with the celica ones? Anyone knows something about? Last edited by Parmas; 03-31-2009 at 07:22 PM. |
#41 |
nice progress! ^ You have some wiring to clean up!
#42 |
#43 |
Looks like the fuel gauge works ok without the ECU in the car in mine. Don't know about the speedometer yet, will hope for the best.
#44 |
In my case the stock ecu controls basically the dash electronics. The only thing will not work is the tach in that case I have an aftermarket one.
#45 |
Finally today we managed to start engine. We tuned the idling and worked stable. One thing that impressed me is that although the exhuast is cut out from the middle straight tru, the engine was really smooth, at least I expected to be many more louder than that.
Tomorrow will get some pics for the complete setup. |
#46 |
your ride is off the chart man, can't wait to see the final result. please keep us posted!
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#47 | |
mm, yummy...turbo 1nz |
#48 |
Here are some recent pics of the complete setup.
The fuel pressure regulator was not installed because the stock one can hold about 17psi of boost. When I have some more cash ready I will upgrade the intake mainfold and the regulator at once. Because of cash tune up is moved to 2 or more weeks ahead which in the meantime I will install all the gauges necassary and a dedicated computer system into the car to monitor and control the ecu in realtime. |
#49 |
Parmas, I see your engine has a separate distributor for the spark plugs, was this stock on your car?
#50 |
Vroom vroom!
#51 |
#52 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
How are you increasing the fuel pressure in relation to boost pressure if you are not using an aftermarket fpr?
#53 |
The stock regulator is capable of handle a good amount of fuel at 17psi max. When exceeding the 17psi then you need an aftermarket one (at least on the old yaris version)
#54 |
But the stock reg can't increase the fuel pressure to compensate for boost as it doesn't reference manifold pressure. I don't have access to my manuals atm, what is the stock fuel pressure for an echo?
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
