Old 03-09-2009, 09:04 PM   #1
jdms
jdms's Avatar
Drives: 08 Polar white lb
need help with RS emblem
I tried the search thing not a lot of help. Maybe I'm not seeing it but it would be awesome to know exactly where to position it. It's an oem badge part number 75312-52050. Any help would be great and hopefully this will help some other people out.
Thanks in advance
jdms is offline   Reply With Quote
Old 03-10-2009, 12:41 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Are you talking about the one on the grill?
Old 03-10-2009, 10:33 AM   #3
jdms
jdms's Avatar
correct but I have an 08 USDM lift back.
Old 03-10-2009, 11:07 AM   #4
kingstonyaris
Drives: 08 liftback
I put mine on with double stick tape. otherwise you will have to remove front bumper
kingstonyaris is offline   Reply With Quote
Old 03-10-2009, 03:48 PM   #5
^ That is how most people attach it on the USDM car
Old 03-10-2009, 06:23 PM   #6
jdms
jdms's Avatar
Seriously? Wow I was under the impression that it just clipped in. Makes sense that it doesn't but no one's been able to just get it to clip in?
So the best way to securely put it on would be to break off some of the tabs and use a bracket on the back side of the grille and screw it to the badge through one of the openings?
Old 03-10-2009, 09:19 PM   #7
spookz
JDM yO!
Drives: '09 3dr. 5-spd
The tape will hold on well used in conjunction with some of those clips.. My badge never clipped into my 09 grille either =\
.. even though I see 09 Canadian RS models have the same badge clipped in place.. =S
Old 03-11-2009, 11:36 AM   #8
jdms
jdms's Avatar
thanks for all the help guys. I have 2 bumpers (1 for auto-x) so at the first even when I switch, I'll rig up something behind the grille to hold it.
Old 03-11-2009, 04:51 PM   #9
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Off topic here, but do you switch bumpers every time you auto-x? How does that affect the mounting tabs and such? Any durability concerns? Reason I'm asking: I'm thinking about getting a fancy, lower bumper for summer, and putting the stocker back on for winter. In your experienced opinion, how do you think that would work out, switching twice a year?
Thanks!
2006 Red Blitzed RS 5-door
Old 03-11-2009, 05:54 PM   #10
i used to take the bumper off every spring and fall on my xrs to remove the oem lip kit...never had a problem
the yaris is all clips too....its super easy to exchange...
Old 03-11-2009, 07:20 PM   #11
jdms
jdms's Avatar
I'll have to agree with thebarber, but in my experience the under shield on the bottom is a pain in the a$$ so I've been thinking about ripping it off. On the sides where it clips in the tabs on the bumper are kind of flimsey but the part on the car is removable and can be replaced fairly cheaply if you break or wear those out. Just take your time and don't just rip it off a nice firm tug and it will pop out.
Old 03-12-2009, 12:11 PM   #12
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Nice! Thanks!
Oh, and re: OEM RS emblems... the hexagonal plastic grill on North American Yarises are different than the rest of the world... ours are more stretched vertically. So if you got the OEM badge from (say) Thailand, it won't clip on our grille... maybe theirs. If you had a Canadian RS badge, it should fit the North American grille.
Old 03-12-2009, 01:13 PM   #13
kimona
kimona's Avatar
Drives: 2014 White VITZ
Here's my JDM RS badge on the US grille. I cut off most of the clips and used a screw and large washer to secure it from behind. You have to remove the bumper.
Old 03-12-2009, 07:14 PM   #14
jdms
jdms's Avatar
That's exactly what I'm going to do. This should defiantly help some people out.
really appreciate all the help.
Old 03-12-2009, 07:24 PM   #15
IllusionX
Drives: 07 Yaris Sedan Aero
Kimona: JDM?? wtf? yo, that's the RS badge we had on the canadian echo hatchback's...
Old 03-12-2009, 08:27 PM   #16
spookz
JDM yO!
I believe the JDM RS badge has different clip/pin locations to the Canadian RS badge..
Because my JDM RS badge did not fit on my 09 grille properly, even though I tried to fit it in the same position as the 09 Canadian RS.
Old 03-12-2009, 08:58 PM   #17
kimona
kimona's Avatar
Same badges. but with different clips specifically for the JDM grille.
Old 03-13-2009, 09:06 AM   #18
IllusionX
i said for the previous generaion ECHO hatchback....
obviously, it wouldn't fit the yaris :)
vitz front emblem jesse1000 Canada 15 08-30-2010 12:31 PM
YarisWorld Emblem slothman86 Cosmetic Modifications (Exterior/Interior) 54 03-30-2009 06:51 AM
Replacing my front emblem? Danish Yaris DIY / Maintenance / Service 18 02-09-2009 10:27 PM
Emblem questions YarisTom73 Cosmetic Modifications (Exterior/Interior) 13 06-15-2007 10:44 PM
Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 39 05-04-2007 05:20 PM
