Old 03-19-2009, 04:14 PM   #145
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If the Yaris is anything like the echo in the brake pedal department, it is fairly easy to modify the existing pedal and install a dual master cylinder balance bar setup. And no need for a booster either. But you will have to redo all the brake lines, and I wouldn't even bother if you have ABS.
rob323 is offline   Reply With Quote
Old 03-19-2009, 04:31 PM   #146
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Did that came out of a fighter jet or something?
Old 03-19-2009, 04:34 PM   #147
Tamago
Tamago's Avatar
Drives: UZJ100
nope
but i've considered one.
it actually is a good deal if you consider what it does, AND still steers the car ;)
Old 03-19-2009, 04:50 PM   #148
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
LOL Garm, are you going to be running in a 24 hour circuit and stripping your car down to bare metal when you run that steering wheel?
Data acquisition is nice to have, but ever in an emergency and needed to grab on that area for some reason say goodbye, that is unless you are a go-kart and have full lock to lock steering in half a turn and would never need to turn that much?
Old 03-20-2009, 12:30 AM   #149
UPDATES MARCH 19:
Had a lot of fun with Art working on the cars today. We took out his turbo mani from the xB so he could repair/weld a crack it developed. Art got more of the IC piping done.
Then I mounted the AEM air/fuel gauge, next to the Autometer gauges I already had. Came with a white face option, nice match. It's actually the same size as the others.
Hole saw FTW:
Then we removed the gas pedal. The spacing isn't quite the same as the xB (cable pedal), but if I can find an xB pedal with the cable and bracket, we are good to go with a spacer to align the holes.
Old 03-21-2009, 02:42 PM   #150
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You put the gauges on the glove box. Smart!
Old 03-21-2009, 10:13 PM   #151
ha, thanks. I knew I wasn't going to use that space for anything else.
Old 03-21-2009, 10:15 PM   #152
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
yeah, it's not often you'll need gloves in California ;)
Wanted: Forced Induction
Old 03-23-2009, 12:34 AM   #153
UPDATE MARCH 22:
Piping's coming along
Old 03-23-2009, 12:55 AM   #154
my, my, my... taking shape quite nicely!
Old 03-23-2009, 02:34 AM   #155
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
I cant wait to see a final product, my buddy just got back his Eclipse GS-T from the shop, its been there for a year between the buying of parts, rebuilding and beefing up the motor, and all the custom work to get the piping and stuff perfect for the car. It is not tuned and it is a HUGE difference so far, only 7-8lbs on the stock GS-X ECU, but its a pretty little thing, hes going to be using it as a Daily Driver at 14lbs. Were now doing a betting pool at work on how much HP tuned the car is going to have...lol
Just after seeing his car and riding in it, I wish I had the time and money to start putting together a turbo kit, or just swap the F'ing motor already.
Sorry, not to try and threadjack, which I dont think I even came close, lol
Old 03-23-2009, 08:02 AM   #156
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
UPDATE MARCH 22:
Hey garm I am wondering that the turbo is facing right (looking from the engine bay). I think this way you needed to make longer piping to get to the inlet of intercooler. Do you have any other pics without the front bumper showing more the routing of the piping?
Parmas is offline   Reply With Quote
Old 03-23-2009, 01:04 PM   #157
CASTREX
CASTREX's Avatar
His intercooler has the inlet and outlet on the same side (right) That is the trick behind this piping set up!
Is a vertical flow unit.
Actually this way he has the shortest possible pipe routing...
I guess that is one of the good things from turbotoyotas original design.
Old 03-23-2009, 02:28 PM   #158
^ Castrex is correct
Old 03-23-2009, 07:54 PM   #159
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
sweet updates
Old 03-23-2009, 09:51 PM   #160
hehe, re-reading your post. The TurboToyotas kit I bought did not come with piping, but because of the intercooler configuration, it was kind of obvious what routing would be optimum.
In this newer version, the piping is all increased in size, and the filter is now at the top, instead of near the ground (that was NOT a good design the first time!)
Old 03-24-2009, 12:41 AM   #161
Parmas
Parmas's Avatar
That intercooler is a good route you went to although it is not suitable for me since the turbo is facing in the opposite direction!
Do you have any pics of the back engine were the turbo is situated etc...?
Old 03-24-2009, 01:19 AM   #162
no pics back there, but I will take some soon.
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Engine Swap / Turbo.... Sabretooth Forced Induction Forum 10 09-13-2007 06:23 PM
small update on turbo project... joey1320 Forced Induction Forum 26 08-03-2007 04:29 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
