Old 03-21-2009, 10:35 PM   #19
hatchbackkid82
Drives: .
Alright anyone know where i can get a set from i been shopping around no luck
Old 03-21-2009, 10:50 PM   #20
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
http://www.trademotion.com/partlocat...layCatalogid=0
Partznet.com is your friend.
It seems that like it would run about 200 with shipping, for NEW pistons out a 06 prius, not including if you found them used, via Ebay or a salvage site...
Old 03-21-2009, 10:57 PM   #21
hatchbackkid82
Drives: .
thanks
Old 03-22-2009, 12:08 AM   #22
The Prius' intake cam holds the valve open longer while the piston goes up on the compression stroke, pushing air back into the intake manifold. Its effective displacement and compression ratio are both reduced this way, but on the power stroke the exhaust valve stays closed while the expanding gas pushes the piston down nearly to the bottom of the stroke. The gas expands through a higher ratio than it's compressed, extracting more energy. Original Atkinson cycle engines did this through a complicated mechanical linkage that actually varied the stroke. The Prius has a mechanical compression ratio of 13:1, while the Yaris has 10.5:1. The "Atkinson Cycle" intake valve hold-open drops the effective compression ratio of the Prius to about the same as the Yaris.
13:1 is a HIGH compression ratio for a spark ignition engine! Some large Diesels run in that compression range. Might work with E85. Might require a different ECU program to make it work on that fuel.
that's the major problem, our ECU does not like to be touched , not even wined and dined
Yep, partznet.com
Old 03-25-2009, 01:05 AM   #23
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
anyone get crackalackin on this yet?
Old 03-25-2009, 01:32 AM   #24
jkuchta
Drives: 2007 Yaris hatch (red)
I'm thinking that the Prius rods are maybe "as strong" as our stock rods, but not much stronger (if at all). The reason I think this is the case is because the redline on the prius motor is like 4500 or 5K rpm.....much less (force-wise) then our engine.
jkuchta is offline   Reply With Quote
Old 02-20-2011, 02:31 AM   #25
Maitre_Te_Te
Drives: Yaris 08
I know the last reply is 2 years ago but finally.... This modification work????
I think the best for this mod is a complet bloc cylinder 1nz-fxe with a head 1nz-fe!
Maitre_Te_Te is offline   Reply With Quote
Prius Pistons sdyaris Performance Modifications 118 04-02-2013 02:38 AM
Prius Hell! texkid Off-topic / Other Cars / Everything else Discussions 11 03-04-2009 11:26 AM
Stupid prius KSIbucky Tracking, Racing, Auto-X Forum 11 09-26-2007 12:07 AM
ZPIracing Turbo Pistons ZPIracing Forced Induction Forum 22 05-29-2007 04:39 PM
Toyot Prius YamilR Photo-Video-Media Gallery 4 02-14-2007 07:54 PM
