Old 03-22-2009, 03:15 PM   #1
jay
Drives: 2006 Yaris LE 5dr AT
Proper coolant level?
Forgive the cluelessness, but what should the proper coolant level be? I just popped a look around my engine, and my coolant level seems much lower vs. where I last remember it (last summer).
Temp-wise right now, it's around freezing outside, and the level is ~1/2 way b/w the "full" and "low" marks. Is this normal, or should I be adding more fluid? I have no idea where the fluid could've went, there are zero fluid leaks on the garage floor. I've been using the block heater for ~2.5hrs in the morning, all winter long - but I've been doing that since I got the car years ago.
jay is offline   Reply With Quote
Old 03-22-2009, 03:22 PM   #2
supmet
Drives: 2007 4 Door Yaris
"The coolant level is satisfactory if it is between the "FULL" and "LOW" lines on the resevoir."
page 260 of the 2007 yaris sedan manual.
Old 03-22-2009, 04:48 PM   #3
jay
Thanks for the confirmation supmet. In the strictest sense the level is OK, and there is no reason for immediate concern.
However, is this scenario similar to engine oil level - where > min is OK, but level = max is the optimum. I'm also confused as to the processes behind the coolant apparently getting "consumed".
Old 03-22-2009, 05:12 PM   #4
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Mine is exactly there and I've asked the same quiestion to myself LOL
Thanks for the answers
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 03-22-2009, 05:23 PM   #5
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Mine was there as well, I just went to the dealership and bought a jug of the premixed coolant and topped it off.
The manual states you shouldn't have to flush until 160,000km I believe.
devinlamothe is offline   Reply With Quote
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 02:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 07:55 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 07:51 PM
Replacing Coolant ttufrosty DIY / Maintenance / Service 3 09-07-2007 12:03 AM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 01:26 AM
