![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Another S/C'd member worried about his AFR
I am posting the dyno printout for another Blitz S/C'd forum member who is worried about his AFR. His dyno technician would not perform a third pull because he did not want to be responsible for damaging this member's engine due to the lean readings.
Without access to a ScanGauge to indicate ignition timing, I do not know if he is facing a problem or not. He is not experiencing any pre-ignition due to the use of octane booster but that gets to be an expensive practice. Largeorangefont, he has specifically asked for you to weigh in on this. I can post the HP curve if that would be helpful. Thanks.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood Last edited by LtNoogie; 03-23-2009 at 09:47 AM. |
Bathroom + Laptop = <3
on top of being unsafe in some cases, you are losing a ton of power. If he has some money to throw around, i heard the SMT8 by perfect power might be a viable solution
![]() ![]() Drives: 2006 Mazda3 Sedan Join Date: Jun 2007
Anybody tried a Megasquirt on a Yaris? If the ECU is rejecting the piggybacks maybe it's time to go standalone.
#4 | |
H8R
Octane boost wouldn't have that much effect on the A/F ratio unless he was running C-10 or better. Did they try to advance or retard the timing at all before he refused to run the car anymore?
lol yeah, everyone thinks megasquirt is a god send. It is very crude, but it works well if you know how to use it. On a newer car like this i can see it being a bitch to work with. Money better invested elsewhere.
H8R
Agreed 110%
Who said Yaris was slow?
As ANY other stand alone and even piggy back out there... a Megasquirt would have to be hardwired. That is a pain yes... but is not any different from the other stand alones out there. With any stand alone ECU you NEED to know what you are doing if you want to doit right. I'm not saying that the Megasquirt would work or not in a Yaris... but ease of installation should not be factor... There are other modern cars running just fine with Megasquirt. There is one reason we have no one (other than Garm's in process project) running a standalone... and that is the cost of it. And basically that is the advantage of the Megasquirt... it's low cost. So I will have to disagree and say that until some gives a valid reason (different from hardwire is a pain) why the Megasquirt would not work on Yaris... it should remain on the table as one good option. Since basically 90% of the forced induction Yaris won't be pushing the limits... fuel and timing control on a basic way is the only thing they need. Is there anyone with actual knowledge on Megasquirt that wants to chime in? |
#8 | |
I'm not saying a MegaSquirt or any other standalone would be easy, I'm just looking at it from the perspective of needing something effective. If you can't cooperate with the stock ECU take it out of the picture for fuel delivery.
Yeah, installing it would be a cast-iron bitch. The upside is that once you did get it installed and tuned right it would work. And continue to work, despite whatever psychotic episode the ECU decided to throw.
Yeap, on a car like the Yaris you will want to leave the OE ECU on the car if you want to keep all the standard features.
Ideally some one would want to take control only over the fuel and timing and use a MAP sensor to tune from... and let all other functions to be handle by the OE ecu. That would be the easiest way to do it. First time is the hardest... and the most expensive.. But if someone with the knowledge can figure a way to make it work... and document the process... Then it will be a breeze for the people coming behind... So, who wants to be the pioneer!!!! |
I forwarded the dyno sheet to Blitz, that's the best I can do to be helpful.
Hey let's solve my problem! What the fart is wrong here!? I only got a 20whp gain with a headerback 2.25" exhaust setup. Noogie got 27whp gain with only an axleback and header as his exhaust upgrades. I want to shoot myself. Oh yah, and my torque got worst! lol. I am in a deep depression as of now.
Here are my HP dyno charts from the resent run. Below will be the old sheet. (Like stated in first post #1, My dyno guy said I'd probably make more HP in higher RPMs, but he did not want to do any harm to my engine, so he didn't.) So I was reading in noogie's "How to cure a lean condition thread" and I am kinda confused... Largeorange front was saying that noogie's readings are OK, if the blitz kit has retard timing? So if that is the case, I would not be running lean either? ![]()
See how inaccurate the butt dyno was? My 27 HP gain is before I tune the car some more. It's now a matter of dimishing returns. How much more money do I want to sink into this for marginal gains. Give me another 30 HP and I may dump a few more bills into it. I just don't want to be the first Blitz owner to blow up his engine.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#14 |
Yah, but I got problems. I only got a 20whp gain with a manual! I should have had a bigger gain than you. If I could get an additional 30 HP gain from this kit, I am all for it. But I am not done with my current problem. I still feel "robbed" of HP that I should have gotten. All that money, all that time, and for 20whp.........
Is my lean condition worst than yours Noogie? |
#15 |
My AFR was actually worse than yours. Sorry for the messed up formatting of the tabular data. My RPMs are the second column. AFR the last column.
AFTER SUPERCHARGER Code:
s RPM x1000 hp ft-lbs Air/Fuel
0.24 4.10 N/A N/A 14.64
0.58 4.20 88.67 110.88 14.91
0.97 4.30 93.31 113.97 14.59
1.40 4.40 93.61 111.73 13.77
1.79 4.50 96.69 112.85 13.45
2.19 4.60 98.06 111.96 13.64
2.60 4.70 100.11 111.87 13.79
3.00 4.80 100.07 109.49 13.80
3.42 4.90 101.35 108.64 13.85
3.80 5.00 104.52 109.79 13.90
4.23 5.10 103.96 107.06 13.96
4.64 5.20 103.46 104.49 14.13
5.07 5.30 104.02 103.08 14.17
5.50 5.40 104.64 101.77 14.14
5.94 5.50 105.85 101.08 14.12
6.39 5.60 106.11 99.52 14.28
6.84 5.70 109.51 100.90 14.38
7.29 5.80 111.59 101.05 14.37
7.72 5.90 115.35 102.68 14.27
8.17 6.00 116.62 102.09 14.18
8.64 6.10 116.29 100.12 14.16
9.10 6.20 116.53 98.71 14.07
9.60 6.30 114.51 95.47 14.01
10.12 6.40 112.97 92.71 13.87
10.63 6.50 114.46 92.49 13.79
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood Last edited by eTiMaGo; 03-24-2009 at 03:04 AM. Reason: Use CODE tags to keep tabs ;) |
#16 |
Yah I see that at your 6200 RPMs you were at 14.07. At 6,200 RPMs I was at 13.59. You were leaner than me.
I see that you took it to 6500 RPMs. That was my intended plan, until my dyno guy said no ways. Yours actually wasn't as lean when you took it past 6300. So did you come to the conclusion that you have retard timing and even though these numbers mean you are running lean, you really aren't? ps: I am going to dyno on a dynojet and taking it to 6500 RPMs once I figure everything out. |
#17 |
I may be an idiot, but aren't these numbers showing that you guys are running rich?
14.7:1 is perfect.....then wouldn't anything less be rich of peak? Would anything over 14.7:1 be lean (like 15:1 etc.)? |
#18 |
Your logic is right... the higher the number the leanest,
However your point of reference is wrong... 14,7:1 would be the perfect number at idle or when crusing, not under boost. Under boos you need to run much richer than that to be on the safe side... Ideally these guys should be around 12:1 under boost... that is why they say a 13.5 or a 14 is dangerously lean... |
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
