Old 03-18-2009, 10:04 PM   #1
pismo61
Drives: 2012 SE
Tow Bar for Yaris.
Is there a tow bar for the Yaris? Tried the search as of 2006 there is not.Thanx Tom
pismo61 is offline   Reply With Quote
Old 03-18-2009, 10:28 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Yes there is , but might not be available in your area , Talk to your toyota branch, http://techdoc.toyota-europe.com/Aim.aspx?menuitem=2
Here is a link that should help. Click on SEARCH AIM , then click on the boes to fill in info required.
Old 03-18-2009, 10:33 PM   #3
pismo61
Drives: 2012 SE
Just to make it clear this would be for towing the Yaris.
Old 03-18-2009, 10:50 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
As in a A frame towing set up .
i would say you would need to get one custom made.
Old 03-24-2009, 07:36 PM   #5
ArtS
Yes, tow equipment is available for the Yaris. I just finished adding a Roadmaster Base Plate to the Yaris. It connects to a Roadmaster Falcon2 tow bar. I purchased these from PPL Motor Homes in TX. They are all installed now and work great. I hardly know the Yaris is behind my Roadtrek (Chev 3500 class B) when towing.
ArtS is offline   Reply With Quote
Old 03-24-2009, 07:40 PM   #6
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Would like to see that lol
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 03-24-2009, 07:44 PM   #7
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
I thought you can't flat tow the Yaris...?
Old 03-24-2009, 07:50 PM   #8
ArtS
Yaris Being Towed
Thought I would try and post a photo here to answer those who are interested in Yaris as an RV accessory.
Old 03-24-2009, 08:03 PM   #9
You can't flat tow an automatic. M/T different story.
Old 03-24-2009, 11:18 PM   #10
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
umm since when can't you flat tow an automatic?
same as a manual put the car in neutral
my only question has ever been about how do you keep the front wheels from turning?
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-25-2009, 10:10 AM   #11
regal
Drives: 09 Yaris 3 Dr White LB
I wonder if this would work:
http://americantowbar.com/
regal is offline   Reply With Quote
Old 03-26-2009, 08:14 AM   #12
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Looks like it would work if you had a hard front bumper that you don't mind scuffing up a bit.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 08-14-2009, 01:56 PM   #13
Ron Powley
Drives: Yaris lift back, red
Just purchased a base plate from Blue Ox for Yaris. Fits behind grill with removable parts to stick through the grill for connection to tow bar. Not visible when not in use.
Towing automatic tran is not possible as it does not have oiling if engine is not running.
Ron Powley is offline   Reply With Quote
Old 08-14-2009, 02:01 PM   #14
regal
How muh did the whole setup cost?
Old 08-15-2009, 01:09 AM   #15
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
i use to do it with my Mitsubishi Mirage and it was automatic
Originally Posted by sw07gt
Old 08-15-2009, 01:51 AM   #16
regal
Do you realize with the Mirage in neutral the tranny was spinning high speeds with no fluid circulation?
I'm intetesred in a setup like this for my Yaris but have no idea what the oricing is like. Also do you lose ground clearance?
Old 08-15-2009, 09:01 AM   #17
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
As for flat towing an AT Yaris, there's an interesting fix. I found it the other day when a guy in a silver Yaris hatchback with stickers all over it came up behind me, beeped, roared past me and zigzagged aggressively and hazardously through two lanes of heavy traffic to get about 4 cars ahead of me by the next turn. I was negatively impressed by this behavior and googled up his vanity tag, which I think said "REMCO." (REPCO?) Among several possibilities for the name I found this cool site for car towing equipment that includes an electric pump that circulates transmission fluid from the pan through the cooler and lubricating system of the transmission so it can be safely towed. With the electronic odometer, the car isn't registering mileage while towed, either.
http://www.remcotowing.com/
Old 08-15-2009, 12:54 PM   #18
Shroomster
Shroomster's Avatar
^^^nice coincidence!
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 07:52 PM
NST TRUE Racing Tow Hooks NonStopTuning NonStopTuning 59 01-06-2010 02:45 AM
Tow bar for Yaris dekers General Yaris / Vitz Discussion 8 10-28-2009 06:28 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
