Tow Bar for Yaris.
Is there a tow bar for the Yaris? Tried the search as of 2006 there is not.Thanx Tom
Yes there is , but might not be available in your area , Talk to your toyota branch, http://techdoc.toyota-europe.com/Aim.aspx?menuitem=2
Here is a link that should help. Click on SEARCH AIM , then click on the boes to fill in info required. |
Just to make it clear this would be for towing the Yaris.
As in a A frame towing set up .
i would say you would need to get one custom made. |
![]() Drives: 2007 Yaris Liftback Join Date: Jul 2007
Yes, tow equipment is available for the Yaris. I just finished adding a Roadmaster Base Plate to the Yaris. It connects to a Roadmaster Falcon2 tow bar. I purchased these from PPL Motor Homes in TX. They are all installed now and work great. I hardly know the Yaris is behind my Roadtrek (Chev 3500 class B) when towing.
#6 | |
![]() ![]() The difference between fiction and reality? Fiction has to make sense. --Tom Clancy |
╚══════════RN
I thought you can't flat tow the Yaris...?
Yaris Being Towed
Thought I would try and post a photo here to answer those who are interested in Yaris as an RV accessory.
You can't flat tow an automatic. M/T different story.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
umm since when can't you flat tow an automatic?
same as a manual put the car in neutral my only question has ever been about how do you keep the front wheels from turning?
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
#12 | |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
____________ Old School Cobble Jockey
![]() Drives: Yaris lift back, red Join Date: Aug 2009
Just purchased a base plate from Blue Ox for Yaris. Fits behind grill with removable parts to stick through the grill for connection to tow bar. Not visible when not in use.
Towing automatic tran is not possible as it does not have oiling if engine is not running. |
#14 | |
How muh did the whole setup cost? |
#15 | ||
USAF_SrA_E-4
Do you realize with the Mirage in neutral the tranny was spinning high speeds with no fluid circulation?
I'm intetesred in a setup like this for my Yaris but have no idea what the oricing is like. Also do you lose ground clearance? |
Half a Bubble Off Plumb
As for flat towing an AT Yaris, there's an interesting fix. I found it the other day when a guy in a silver Yaris hatchback with stickers all over it came up behind me, beeped, roared past me and zigzagged aggressively and hazardously through two lanes of heavy traffic to get about 4 cars ahead of me by the next turn. I was negatively impressed by this behavior and googled up his vanity tag, which I think said "REMCO." (REPCO?) Among several possibilities for the name I found this cool site for car towing equipment that includes an electric pump that circulates transmission fluid from the pan through the cooler and lubricating system of the transmission so it can be safely towed. With the electronic odometer, the car isn't registering mileage while towed, either.
http://www.remcotowing.com/ |
^^^nice coincidence!
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 06:25 AM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 07:52 PM |
| NST TRUE Racing Tow Hooks | NonStopTuning | NonStopTuning | 59 | 01-06-2010 02:45 AM |
| Tow bar for Yaris | dekers | General Yaris / Vitz Discussion | 8 | 10-28-2009 06:28 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-06-2008 12:37 AM |
