![]() ![]() ![]() Drives: 2008 Sedan A/T Silver Join Date: Nov 2008
Cabin Air Filter Question
I saw Bailout's guide on making your own Cabin Air Filter. Thought I'd give it a shot. My question is, does the car use the air filter when using either the fresh air setting and the recirculate?
Thanks. |
Both.
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
both
Did your Yaris come off the lot with one? Mine did not but didn’t realize it till I was 600 miles up the road.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
Mine didn't come with one either. Ok, thanks for answering the question. Do you think I'll notice a major freshness from installing it?
I did notice a good deal of difference but I thought it was too restrictive. I ended up making a few DYI filters out of a single house air filter and duck tape. I change the filter every 5,000 miles or so.
4 of the DYI filters are 5 bucks or less depending on the quality of filter you get.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2009
has anyone used the "CUT TO FIT" filters?
I have extra and wondered if this will work also.. |
Yes mine are cut to fit and work good. I change mine about every 5,000 miles but I get that many miles fairly fast. I did buy a c38188 air filter and keep it in its box and use it for cutting new ones.
I can make 4 for under $5 depending on what type of filter I buy. If you read this thread I’m sure you will find a huge amount of info… http://www.yarisworld.com/forums/showthread.php?t=5471
#8 | |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
. . . . . . . .. . . . . .,.-”. . . . . . . . . . . . . . . . . .“-., . . . . .. . . . . . ..,/. . . . . . . . . . . . . . . . . . . . . . . ”:, . . . . . . . .. .,?. . . . . . . . . . . . . . . . . . . . . . . . . . .\, . . . . . . . . . /. . . . . . . . . . . . . . . . . . . . . . . . . . . . ,} . . . . . . . . ./. . . . . . . . . . . . . . . . . . . . . . . . . . ,:`^`.} . . . . . . . ./. . . . . . . . . . . . . . . . . . . . . . . . . ,:”. . . ./ . . . . . . .?. . . __. . . . . . . . . . . . . . . . . . . . :`. . . ./ . . . . . . . /__.(. . .“~-,_. . . . . . . . . . . . . . ,:`. . . .. ./ . . . . . . /(_. . ”~,_. . . ..“~,_. . . . . . . . . .,:`. . . . _/ . . . .. .{.._$;_. . .”=,_. . . .“-,_. . . ,.-~-,}, .~”; /. .. .} . . .. . .((. . .*~_. . . .”=-._. . .“;,,./`. . /” . . . ./. .. ../ . . . .. . .\`~,. . ..“~.,. . . . . . . . . ..`. . .}. . . . . . ../ . . . . . .(. ..`=-,,. . . .`. . . . . . . . . . . ..(. . . ;_,,-” . . . . . ../.`~,. . ..`-.. . . . . . . . . . . . . . ..\. . /\ . . . . . . \`~.*-,. . . . . . . . . . . . . . . . . ..|,./.....\,__ ,,_. . . . . }.>-._\. . . . . . . . . . . . . . . . . .|. . . . . . ..`=~-, . .. `=~-,_\_. . . `\,. . . . . . . . . . . . . . . . .\ . . . . . . . . . .`=~-,,.\,. . . . . . . . . . . . . . . .\ . . . . . . . . . . . . . . . . `:,, . . . . . . . . . . . . . `\. . . . . . ..__ . . . . . . . . . . . . . . . . . . .`=-,. . . . . . . . . .,%`>--==`` . . . . . . . . . . . . . . . . . . . . _\. . . . . ._,-%. . . ..`\.
First time DIYer
DOH!
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs |
![]() With no filter I ran the fan on 1 all the time. With an OEM filter I was running it on 2. I read the DYI and went to the big blue store and got an air filter and started cutting. Once I had the 4 cut out I grabbed a roll of duct tape. I run the fan on 1 and it has just a bit of restriction on it but not much. Look at the type of filter you buy and should be able to tell how mush of what kind of junk it will hold.
Remember all filters are going to be restrictive. Less restrictive=More dust particles getting into your car. More restrictive=Less dust particles into the car
First time DIYer
hmm. now that i think about it, i should probably change mine.. it's been about a year since i put it in and haven't touched it since
| DIY Cabin Air Filter | BailOut | DIY / Maintenance / Service | 105 | 06-20-2019 12:59 PM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| HEPA filter for cabin air | lh59 | DIY / Maintenance / Service | 2 | 03-23-2009 09:17 PM |
| Cabin air filter | jambo101 | DIY / Maintenance / Service | 15 | 11-20-2008 11:33 AM |
