Old 04-02-2009, 03:26 PM   #1
Syroyizhka
Syroyizhka's Avatar
Drives: 2007 Yaris Hatchback
Exclamation Is it possible to have an power lock on the hatchback turnk?
I had power locks installed for me by the same company that installed my remote starter, however they did not connect it to the trunk, so if i don't lock it manually, if i close the doors, someone can still get it through the trunk lol! anyway to get that done? did anyone come up with a release switch to open a hatchback trunk?
sorry for misspell on the title, i was in a hurry *trunk*
Syroyizhka is offline   Reply With Quote
Old 04-02-2009, 03:42 PM   #2
hatchbackkid82
Drives: .
What's a turnk? I hope my car has a turnk
Old 04-02-2009, 03:45 PM   #3
jdinrc
jdinrc's Avatar
Drives: 2009 Yaris Blazing Blue 3dr
My '09 HB with the power package has a powered lock for the hatch that locks and unlocks remotely.
jdinrc is offline   Reply With Quote
Old 04-02-2009, 11:26 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
yeah... a lot of shops will require you to buy an optinal pin sensor to have installed in the hatch area, then the $40 labor to install it.. so a hatch sensor will probably cost you $50 extra... its worth it I think, Also make sure there is a starter kill.
Auto-lock isn't hard.
Old 04-03-2009, 09:22 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
i last had my echo hatchback... wires were already ran from the hatch lock to the interior...
it was kinda hard to install aftermarket actuators for the rear lock. so i went and bought the OEM lock motor (100$ at the dealer)
Old 04-04-2009, 01:01 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
good point, OEM motors are the way to go... its possible to do an actuator on a wire cable, but from what i've heard, you probably will end up having to readjust from time to time because of it loosening up.
Old 04-04-2009, 02:26 PM   #7
Syroyizhka
Syroyizhka's Avatar
what is an actuator? is it aftermarket power locks?
Old 04-04-2009, 07:23 PM   #8
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
its basically a little piston that can push/pull and object. Generally you have to use two relays with them to make them work... You hit the button and 1 relay engages and you get a push... Hit the button a 2nd time and the other relay engages and you get a pull....and so on.
they are used for all sorts of things, auto locks being the most common, but also on stereo installs for amp racks.
Old 04-05-2009, 03:38 PM   #9
Syroyizhka
Syroyizhka's Avatar
Thanx for the explanation! I have a remote starter installed, and my power locks are connected with it, i had actuators installed for my doors since they were manual from factory. my question is: How can i program my remote starter to use my aux buttons on my remote for example, turn on or turn off the lights, honk a horn, or even roll down my windows (since i have my kit coming in for the manual to power windows conversion)
hatchback trunk power
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 05:14 PM
Power Lock button?? cyberfrogg DIY / Maintenance / Service 25 03-26-2009 11:16 PM
Power hatch lock? paultyler_82 DIY / Maintenance / Service 5 09-08-2006 02:15 AM
using regular power lock kits with cable style twixt DIY / Maintenance / Service 4 08-12-2006 02:18 PM
