![]() ![]() ![]() Drives: 2008 Yaris Liftback Join Date: Oct 2008
I'm not all that mechanical so I was wondering if you guys could ballpark me a figure $$$ to expect to pay for an install?
I love momentum.
I'd say a couple hundred dollars with alignment, maybe a bit more. That is assuming you have a trusted local mechanic to use. At the dealer, god only knows what they'd charge you.
If you get springs and struts I bet it would cost less, since it's a straight swap. The mechanic wouldn't have to remove your stock springs from the struts and then put the new ones on. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
You really don't need to be very mechanically inclined for a spring install. I'd suggest doing it yourself.
![]() ![]() Drives: 08 Hatch Join Date: Mar 2009
100 flat no more.
I had mine done for $80. TAMAGO did a geat job on my white lady!
GioBatera
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Hah, I was quoted no less than $600 around where I live. I said to hell with this and did it myself. Prior to this, the only mechanical experience I've had was installing new headers in a buddy's 240sx. Find a good DIY thread on here. It'll show you what to do. You only need a few tools and about four hours. Good luck!
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
A good shop with all the good tools would be 1 to 1.5 hours of labor they were reusing the struts. Depending on where you go you’re looking at other fees for you bringing parts. Some will quote you an extra hour of work incase there are problems and then charge anyways when they only need 5 minutes of it.
If you know someone with some air tools and can get there help rent a spring compressor and a 12 pack and will be done in 4 hours. Just make sure you check everything the next day and retighten it all after 500 miles.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
| anyone have DIY install inst for lowering springs swapout??? | Stargate YARlantIS | General Yaris / Vitz Discussion | 1 | 10-20-2008 03:18 PM |
| Is it practical to install stiffer shocks without also installing lowering springs? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 01-18-2007 01:23 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 12:40 PM |
