Old 08-09-2007, 10:58 PM   #37
Pavel Olavich
Drives: 2007 Yaris LB
Originally Posted by cleong View Post
My GPS indicated a real max speed of 192kph (119mph). I am using a Garmin Nuvi GPS.
Because I was running a smaller than standard tire, the speedometer read a bit optimistic (200kph or 124mph).
Stands to reason that if I used a larger tire, I might be able to raise the real max speed a bit.
However at this speed, the engine is pretty much close to the redline cutoff, so I would say that is all the car would do given this combination of engine and gearbox.
Nope...going larger in the tire DECREASES torque at the front driving wheels...you will lose speed.
Pavel Olavich is offline   Reply With Quote
Old 08-09-2007, 11:09 PM   #38
joe keeney
Drives: yaris 2 door hatch
I freak a lot of people out. It;s a fast little car.
joe keeney is offline   Reply With Quote
Old 08-10-2007, 02:11 AM   #39
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
You're right about decreasing torque. But you're wrong about losing speed.
A smaller tire buys you acceleration at the expense of speed. A larger tire trades acceleration for better speed.
So by using a larger tire, I would be a tad slower to get to 60mph but I can hit a higher V-max before I run out of engine revs.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 08-10-2007, 02:22 AM   #40
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
+1
+1 ... think of it this way... we have more torque to the wheels in 1st gear, but we have a higher top speed in 5th ... larger tires raise the over all gear ratio
Pavel Olavich was probably assuming that the top speed is drag limited... which doesnt seem to be the case...
fu_im_from_texas is offline   Reply With Quote
Old 04-08-2009, 10:57 AM   #41
Kiyoshi Manabe
Drives: Toyota Yaris(Vitz) 1.3U-L
My Yaris 1.3U-L with CVT transmission:182.8km/h(S/D mode) 190.68km/h(D mode) 2004-made SCP13(previous generation).
According to the rumour,the European editions of both current and previous generation Yaris with 2SZ-FE 1296cc engine,can go up to 126/127mph(about 204km/h);if they are manual versions! This data is well above its manufacturer data of 109mph(175km/h).
Along with it,Youtube shows a previous generation Yaris 1.3 indicates 199km/h on its digital speedo,while its tachometer shows 6100rpm,thus it would mark up to 203.74km/h!!!!(33.4km/h per 1000rpm on 5th gear;multiplying 6.1 to 33.4km/h results 203.74km/h! Let's calculate it.) This number of max speed is about as fast as that of the Volvo S60 2.4(140ps) and the Renault Megane II 2.0(133ps), so the 1.3-liter version Yaris(87ps) would be a kind of giant-killer!
Kiyoshi Manabe is offline   Reply With Quote
Old 04-08-2009, 11:37 AM   #42
firebob
Drives: 09 yaris
2 year old thread
But most people live in the past. But they did look before starting a new thread on it…
When it’s stock there’s an iffy spot about the 90’s but once you kill the 90’s it goes away. With the rear sway bar I didn’t get the iffy spot. Both times I thought I would put a hole in the carpet trying to get it to go faster.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 04-08-2009, 01:14 PM   #43
IllusionX
Drives: 07 Yaris Sedan Aero
oh.. 200+ kmh was the faster ever reached in a Yaris.
http://www.yarisworld.com/forums/showthread.php?t=16027
Old 04-08-2009, 01:45 PM   #44
nerp
Drives: 2009 3dr LB Meteorite Metallic
I'm still breaking in my engine. I haven't gone over 65mph yet! haha.
nerp is offline   Reply With Quote
Old 04-08-2009, 02:14 PM   #45
kenkyd
kanye
Drives: 11 Corolla S
Send a message via AIM to kenkyd
ever since i put my yarisworld sticker on my car i can do 150 no problem
kenkyd is offline   Reply With Quote
Old 04-08-2009, 04:18 PM   #46
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Originally Posted by blacksan View Post
I still have not figured out the gear ratio. In my opinion reverse is high. Does anyone know what the trans axle ratio is?
So how fast will it go in reverse?
Old 04-08-2009, 04:27 PM   #47
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
It'll do 200 falling from an airplane.
Old 04-08-2009, 04:40 PM   #48
41magmag41
Drives: Loaded 2007 mica silver sedan
Should hit 220 or their abouts dropped from an airplane. Max terminal air speed that can be attained. LOL
41magmag41 is offline   Reply With Quote
Old 04-08-2009, 04:46 PM   #49
supmet
Drives: 2007 4 Door Yaris
2 year old thread
If he made a new thread your response would be - "Use the search function, there's already a topic on this"
Old 04-08-2009, 04:55 PM   #50
supmet
why post in an old thread that has covered the topic from A to Z? half the people who were in that thread are either banned or not here anymore. and there is no need to post a thread about it for th Nth time
I think it would just be easiest to have everyone check with you before posting anything....
Old 04-08-2009, 05:03 PM   #51
supmet
maybe they should i bet it would cut down on useless questions that are covered in the FAQ thread.
now how bout you go back to your business and stop talking bs about things you have no clue about aight.
I'll take your hostility as a sign you know I'm right
Old 04-08-2009, 11:41 PM   #52
Yaris Hilton
Smile
You're thinking of max terminal airspeed for a human body at near ground altitudes. Terminal airspeed for other objects depends on their ballistic coefficient, determined by mass density and shape, and air density. Heavy bombs can and do fall at supersonic speed when dropped from high altitudes. For that matter, a human dropping from a balloon in the rarified upper atmosphere can briefly go supersonic.
Don't know how fast a Yaris would fall if you dropped it out of a plane, but I'd bet 200 MPH wouldn't be way off.
Old 04-09-2009, 11:57 AM   #53
Bredayaris
Bredayaris's Avatar
Drives: Toyota Yaris 1.3 vvti cvt
I've driven 196 km/h (122 mph) at the German autobahn with my diesel Yaris.
It was still going but i saw warning lights ahead so stepped on the brakes.
A Opel Corsa cdti tried to go fast too but when i was going 170 km/h it stayed way back.
Bredayaris is offline   Reply With Quote
Old 04-09-2009, 12:02 PM   #54
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
depends how steep the hill is....
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Yaris Crashed! elsteverino889 General Yaris / Vitz Discussion 13 11-06-2006 02:59 AM
