Old 04-12-2009, 02:51 AM   #1
Frankd1
Drives: 2008 RS, 5spd
Reverse gear crunch
I'm not sure if this is normal but here is my scenario.
If I push the clutch in and shift into reverse gear right away I get a crunch of the gears.
If I push the clutch in and wait a couple of seconds and then shift into reverse there is no gear crunch.
This only happens when I shift into reverse gear rather quickly after pushing the clutch in, so as a result I have made it a habit to push the clutch in and wait a couple of seconds and then shift into reverse.
The reason I am asking is that my other vehicle that is a 5spd (not a Toyota) does not do this no matter how quickly after depressing the clutch pedal I shift into reverse.
Does this occur because the syncros need a few seconds to line up?
Frankd1 is offline   Reply With Quote
Old 04-12-2009, 02:53 AM   #2
yeah pretty much... What I read before, I think it was originally toyota's recommendation, go into 1st or 4th gear first (at a stop), then into reverse, this will align the synchros best.
Old 04-12-2009, 02:58 AM   #3
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Word on the street is that the reverse gear on the Yaris is square. Never personally had it cracked ope though^_-
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 04-13-2009, 12:41 PM   #4
Frankd1
Ok thanks guys! If its normal thats fine, I just wanted to make sure that it wasn't a sign of potential transmission problems down the road.
Old 04-13-2009, 01:27 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
it happends on a new car as well but for 15 years of driving stick i got use to putting it on 2nd gear b4 reverse and im grindless ever since.
Old 04-13-2009, 01:43 PM   #6
oilman930
Drives: 2009 Yaris S Hatchback
The Yaris gearbox has a straight cut, unsynchronized reverse gear. Which explains the gear whine moving in reverse and the problem with getting the gear shift into reverse. The gearbox was designed in the mid 1990's before transmission makers like Getrag were adding a synchronized reverse to their gearboxes.
oilman930 is offline   Reply With Quote
reverse gear..quick question.. Yaris2910 DIY / Maintenance / Service 10 01-11-2011 06:14 AM
reverse gear whine jonismyname DIY / Maintenance / Service 7 03-12-2009 02:17 PM
Reverse gear? polly General Yaris / Vitz Discussion 26 03-05-2009 11:39 AM
Yaris 2007- How to Restart Multimode gear? ronen DIY / Maintenance / Service 1 02-21-2009 06:09 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
