![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2009
Is it when you put in 1st gear and you start going and it feels like the tires are burning out but they're really not?
Learn to Relax
Yes. The engine is turning over, but the car's speed, in gear, doesn't match the RPM of the engine. When you shift, let out the clutch quickly while gunning the engine, and if the car doesn't accelerate, it's slipping.
time for a new clutch
easiest way to find out is try gun it on 3rd.
rev it to ~3000rpm, if your car stalls, then your clutch is still good. that's what Toyota did back in 2005 when i told them the clutch of my 05 echo is slipping. It never stalled, and just went as if it was on 1st :P |
my friend's old car used to do that, hopefully that won't happen to my Yaris, that's expensive to get fixed isn't it, he ended up throwing the car away :)
Half a Bubble Off Plumb
Replacing a clutch is normal, expected maintenance with any manual transmission, just like replacing tires and brake pads. Taking care of your clutch by not slipping it any more than absolutely necessary, never using it to hold the car on hills, not making "dragster starts" and never using it to reverse motion (that is, fully stop when you're backing up before you put it in a forward gear to drive away) will make it last much longer. But eventually it's got to be done.
just curious wen this sad day comes n i have 2 buy new clutch, how nuch is it?
#8 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Sorry, I don't know how much it costs to do that on a Yaris, sure would like to know, as well. |
yes it is. my clutch is fine for now, but i like to do some hardcore accelerating though... now that i look back, i wonder how much damage i've caused :)
| Tags |
| clutch slips |
| 07 clutch burning? driver or design? | kennywhy | DIY / Maintenance / Service | 22 | 10-01-2009 01:03 AM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
| Street/Race Clutch | dngz | Performance Modifications | 10 | 06-23-2007 12:05 PM |
| c one motorsport clutch line(pics) | badhabitz | Performance Modifications | 6 | 07-31-2006 10:08 AM |
