Old 04-14-2009, 03:00 AM   #1
calicruisin
Drives: 86 GTS
How do you remove front lip?
I tried searching but came up with nothing. I want to replace the oem front lip on my 4 door Yaris S but I dont know how to remove it. I took off the 2 screws on each side and the 4 bolts underneath but the thing just wont come off. What am I missing? I dont have a jack at the new place I moved to so its hard since its far away from home so its making things tough to look underneath.
calicruisin is offline   Reply With Quote
Old 04-14-2009, 03:10 AM   #2
ruimond
Drives: Yaris YR
Pretty sure there's at least some sort of tape or adhesive glue used. So it won't just come off once the screws are off.
My side skirts i just got done recently are bolted on and glued on.
You might have to heat up the sides abit with a hairdryer or heatgun im guessing. Im not 100% on that so you might want to wait till someone else chimes in.
Old 04-14-2009, 03:48 AM   #3
calicruisin
Drives: 86 GTS
It might have at one time but I dont think that it is anymore or maybe not the whole lip anymore. Like I can move it somewhat but not the whole thing. Like I can bend the sides but not so much in the middle.
Old 04-14-2009, 04:13 AM   #4
Look around the lip. Do you see a black rubber-looking thing? If so, I think that's the adhesive (in addition to the bolts/screws).
Old 04-14-2009, 04:24 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
there are at least 4 clips behind the lip. I simply yanked it out whatever was holding in the middle.
the little rubber band do adhere a little, but that's just a little. When the lip is out, you are left with a bunch of holes on the lower bumper :P
Old 11-11-2019, 08:16 PM   #6
Niki Knuckles
Drives: RS
Exclamation HELP!
Can someone tell me where to get the rubbers in between the panels and the moldings, once you un-glue the aero package?
Niki Knuckles is offline   Reply With Quote
Old 11-13-2019, 08:24 AM   #7
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Maybe the dealer... although I have a feeling they will tell you you have to buy the entire moulding.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
My new vios grill and front lip splitter Pics Inside =) YarisSedan Cosmetic Modifications (Exterior/Interior) 10 02-21-2009 12:51 AM
2009 Sedan Aerokit Front Lip Part #? Split Cosmetic Modifications (Exterior/Interior) 9 11-26-2008 07:19 PM
How hard is it to remove side skirts and front lip on 08 sports package? dono37 Cosmetic Modifications (Exterior/Interior) 15 09-26-2007 05:28 PM
Front Lip on S has peeling paint... fnkngrv DIY / Maintenance / Service 7 09-05-2006 03:32 PM
