#55 |
![]() ![]() ![]() Drives: 2007 MX5 Join Date: Feb 2009
Then is the Hydra the same as the MS?
#56 |
IDK...but a lot of people have said that you can use it as either a piggyback or as a full stand alone.
#57 |
The Hydra has full standalone capability (at least their Nemesis 2 does), including timing, peripherals (a/c, power steering, etc), and other functions. Much like the AEM EMS I'm using, or a MoTeC, etc.
MegaSquirt gives control over fuel only - the ECU is still doing most of the work to control the motor.
#58 |
#59 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Mouse is right... Megasquirt can be used as either a standalone or a piggyback. But you may lose the vvti... Unless someone has figured that out.
I used megasquirt as a piggy back on the 1nzfe and its a full standalone on the 4age.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#60 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
Got some new info on AFR, I'll repeat the rest of the stuff as well. Looks like my experiences pretty much parallel camelll's.
Air Fuel Ratio: * 11-12 range at wot in open loop (making up to 8 psi) * mid 14s-low 15s in closed loop (both on and off boost) * steady at 16 during DFCO (open loop) Fuel Controller Wiring: Splice clips (the good kind, not the shit ones from the kit )Spark Plug: NGK 7 heat range plugs Pump Gas Quality: BP 93 octane plus lucas oil octane booster I just got the wideband a/f gauge in over the weekend so I'll continue to keep an eye on it. Similar to what camelll said, I see a brief delay in going to open loop at wot, but I see the same delay when entering dfco, so it may simply be may be the scangauge catching up. My main desire would be to eliminate long-term use of the fuel additive to prevent knocking. |
#61 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
KK, have you tried a tankful without the addditive? I believe that Yaris T-sport mentioned that he was able to stop using the octane booster. I don't understand why other than maybe the ECU was able to learn and adjust. Doesn't make sense to me.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#62 | |
It runs so well with the octane booster I almost don't mind the added expense, but seeing what others have said about the long-term effect on spark plugs does concern me. |
#63 |
Plus.... you shouldn't have to, in my opinion.
#64 |
Well wouldn't we have to because a few people were guessing the blitz kit was tuned to 100 octane in Japan? And if that is true, it comes out to like 95-96 octane in the US?
#65 |
I was thinking the same thing, but Blitz confirmed that they used a USDM car (here in the USA) to install and test their system. I doubt that car had more than 91 in it when they did their R&D here.
I'm emailing them again today to find out what's up.
#66 | |
Thanks |
#67 |
With my limited understanding of engine performance, I thought that when you retard to single digits on timing, you are delaying when the spark occurs to near top dead center. That helps to prevent pre-ignition but also outputs less power than if you had ignited earlier... meaning double digit ignition retardation. Earlier ignition allows for more of the fuel to completely burn.
Someone with more knowledge please chime in.
#68 |
I am going to try larger injectors next. I have to read up on why more fuel prevents pre-ignition.
#69 | |
My ignition timing:
at idle ~5 out of boost ~30 (AFR 14s-15s) under low boost ~15 (AFR 14s-15s) at wot ~10, rarely + briefly single digits (AFR 11s-12s) Quote:
though sometimes I suspect we are all getting crap gas! Seems like lately I've read more posts about stalling and poor performance in other parts of the board than ever before. Hell I dunno </conspiracy theory> Annnnyway, have not tried Shell, I'll have to see if I can find it!
#70 |
you could also look into water/meth injection as a way too cool down the compressed air, though I'm not sure where you'd be able to fit the nozzle!
#71 |
AlexNet0 is fabricating a throttle body spacer with a NOS injection port. Perhaps the water/meth can be injected there. That is way low on my list of mods, though.
#72 |
yeah but inejcting it before the compression takes place, I'm not sure how efficient it'll be? I mean, you basically want the liquid mist to absorb heat (thus cooling the air) and turn to steam...
| i have a q to US owners | FlyingDevil | New YARIS Purchase Forum | 33 | 03-26-2009 09:20 PM |
| Yaris owners in Edmonton,AB | 06vitzRS | Canada | 6 | 02-20-2009 07:38 PM |
| Doctors Vs Gun Owners | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 0 | 01-29-2009 07:36 AM |
| READ YOUR OWNERS MANUAL!! | MadMax | General Yaris / Vitz Discussion | 29 | 12-14-2008 10:38 PM |
