![]() Drives: 07 Sedan S Join Date: Sep 2006
Auto Windows (all of them auto)?
Has anyone done this type of conversion? I don't know if it is possible to have the auto roll down function like some toyotas or lexus have.
Look mum no stars!!
Yes i believe its possible.....i have powered windows, though only my drivers side as that auto feature. Contact your local toyota dealer they might help ya.
But im 90% sure that u can impliment that to all the windows
#3 | |
I love my Yaris!
Drives: White Yaris Liftback 2 Dr. AT Join Date: Sep 2006
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
I would LOVE to have this upgrade!
#5 | |
I think there is some confusion in this thread...When you say auto down, do you mean the one touch roll down the window, or do you mean that the windows can be rolled down using the remote keyless entry fob?
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
there's a hall effect sensor in there and it counts how many revolutions tthe motor makes. so no, it's not just a switch.
but you could put a timed relay in there...and just set up the time for the relay to shut off when it reaches the max height. but then again you'd have to have steady voltage and amperage to the relay or timer...too much of a pita for me to do. |
The easiest way is to use a DEI 530T for auto up/down on both windows (or for a 5 door or sedan, you use a second 530T for the back windows).
I put together a DIY a while back on wiring it up: http://www.yarisworld.com/forums/sho...3&postcount=39 |
