HELP
IM STUCK ON THE CRANK PULLEY INSTALL PLEASE SOMEONE HELP ME I HAVE TO DRIVE TO WORK TOMORROW AND IM STUCK WITH THE CAR IN PIEACES 8157155751 I NEED HELP
205/45/17 Nittos/ KN tyhoon 69 intake EURO areo muffler / DF 210 Springs NST 10% Pulley/ 15% tint 600watt rockford punch 12" subs and amp micro image rocks! |
what are you stuck with on the install? ahve you checked the diy? need more info if you want us to help
ok i have the diy open and i cant get the alternator to go forward
please guys help me out i need to drive to work tomorrow and this bad boy needs to be in one peace
very very VERY gently tap it forward with a rubber mallet. if that dosnt work try taking it off? just make sure you make everything first. maybe try lossening some of the other bolts?
please anyone who can help im freakin
or if nothen else put it abck together and save the install for when you have more time
i have time i think i may have broke something and i just want to put it on and then work what i may have broke
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Were you able to loosen the lower alternator bolt? That one is a bitch to loosen.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
★weeaboo★
When I did mine I didn't bother moving the alternator forward to release tension on the belt, I just removed the crank pulley with the tension on it, and installed the new pulley.
I have the underdrive pulley so I had to pull the alternator forward towards the bumper to increase the belt tension, which was easy. If you have just the lightweight pulley I don't know if that way will work since the diameter is the same, but it may! I'd be worried about cross threading the crank bolt since you might have too much tension on the pulley and it may not seat straight. |
What happened to Klinton? Did he get it fixed? I'm just reading this, and I can't tell what was "broken" exactly.
Drives: yw calls me douche and racist. Join Date: Aug 2007
ZOMGGGG HELPPPPPPPP
i broke my vvti cord to the engine but i got the pulley in and now my car is sitting at toyota and may bot be fixed till monday saddly
#14 |
May be a dumb question but whats a VVTi cord
#15 |
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
I just used a pry bar and gently levered it forward. It didn't take take that much force to bring it forward honeslty. like i coulda put the force of two finger to bring the alternator forward with the pry bar hahaha
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
