Old 04-22-2009, 12:35 PM   #127
ok 07s do not have wires from D3 only the horn wire. i'm trying to find an easier way to tap into the AD4 box ill keep you posted.
It may just be easier to connect to the wire on the ECM instead of trying to get to AD4. The ECM connector is so easy to access under the hood and poking a wire through the giant firewall grommet under the dash is easy as well.
Old 04-22-2009, 12:39 PM   #128
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
so have any of you even gotten the stalk to work yet? lol
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-22-2009, 01:19 PM   #129
Shroomster
Shroomster's Avatar
the stalk will work 100% , the problem is we will most likely need to use jumper wires to connect the rest of the system together , its not a big job but it needs to be done.
short answer...no, but in progress
keep at it you guys....
Old 04-22-2009, 01:34 PM   #130
mrbond
mrbond's Avatar
I'd hope one of you would post a short DIY for connecting the jumper wires. With pictures :P
Have any of you received your stalks yet btw? I'm still waiting on mine, and the tracking number I was given wasn't valid :/
- A Toyota Yaris
- A whut Yaris?
Old 04-22-2009, 01:43 PM   #131
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
+1
Old 04-22-2009, 01:50 PM   #132
mrbond
mrbond's Avatar
it will probably be a team effort between CTScott and I for the DIY. Im off to dive under the dash to figure out a way to get to the AD4 (i swear its almost as well hidden as the Gspot )
Lol, shouldn't be too hard to find then rofl
- A Toyota Yaris
- A whut Yaris?
Old 04-22-2009, 04:33 PM   #133
MGargano
Drives: 2009 Yaris Hatchback
I had the same problem with the tracking number... weird.
MGargano is offline   Reply With Quote
Old 04-22-2009, 05:44 PM   #134
So, I am trying to decide between four pushbutton switches mounted on the left black vertical trim piece to the side of the radio, a miniature 4-way joystick to emulate the stalk, or a four button keypad:
Four of one of these:
or this:
or one of these:
Old 04-22-2009, 06:19 PM   #135
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
OK so I get the dumbshit award of the century here. I was replacing my headlight stalk and at the same time checking the wire from the clockspring, and I swung my arm and accidentally hit the clockspring, and the wire BROKE. So now I have no horn/airbag until a new one comes in (which is $450 CAD). I am so pissed at myself you have no idea lol
Lesson: DO NOT HIT THE CLOCKSPRING OR THE WIRE WILL BREAK!! :(
devinlamothe is offline   Reply With Quote
Old 04-22-2009, 06:25 PM   #136
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
ahhhh! oh no!
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 04-22-2009, 08:38 PM   #137
devinlamothe
are you talking about the clockspring itself being broken or the connecting wires to the D3 connector?
The internal ribbon cable ripped out of the connection on the side ... I tried to see if it could be put back by taking the clockspring apart, but, stupid toyota glued the cable as well as had a clamp. If it was just clamped, it would have been fine.
The one good result, the turn signal is a lot quieter LOL
Old 04-22-2009, 08:41 PM   #138
CTScott, check these out:
http://www.frozencpu.com/products/im...?tl=g4c153s315
this one is the latching one they also have momentary ones
I ran into those, but they are kind of large (~1" in diameter)
Old 04-22-2009, 11:31 PM   #139
IllusionX
Drives: 07 Yaris Sedan Aero
ok so i checked the ECM in the engine bay and the 07 and therefore 08 seem to have the connection to A21 pin 40 (that is the ECM input pin 40) the wire is BLUE. Now this means that the junction box AD4 has this wire and it is accessed by pin 6 on the AD4 junction connector. Now im almost certain the only way to get to AD4 is to take off the top instrument panel.
I tried to find a suitable replacement for the AD4 but it seems this is the only way to get to the ECM pin 40 without having to go through the firewall. Now if someone knows of a fast and easy way of removing the top instrument panel please share your wisdom.
share the wisdom? pull the cluster cover, 2 bolts to remove the cluster and 2 cables to unplug.
pull the glove box, under there, there are 2 bolts that bolts down the air bag. unbolt and unplug the air bag (1 plug if i remember well, and no need to disconnect the battery) and then just pop the dash top cover, it comes right off, with the air bag.
I did it with the mechanics at Toyota. Took less than 5mins.
Old 04-23-2009, 09:39 AM   #140
ok i just found something super cool check this out CTScott:
http://www.nkksmartswitch.com/products/oled.asp
OLED Switches
We experimented with some of those for a work project. They are mighty cool, and about $60 each.
Old 04-23-2009, 10:16 AM   #141
do they come with embedded memory or you need to have a line in to display the images?
The ones that we were playing with had an embedded processor in them, so you could serially upload a .jpg converted to a .hex file.
Old 04-24-2009, 06:24 PM   #142
AlexNet0
AlexNet0's Avatar
has anyone gotten it yet? how long do you think it should take?
Old 04-24-2009, 09:20 PM   #143
Gotten the Ebay stalks or gotten cruise working?
I've been cruising all week with my prototype setup. Today I ordered from Digikey a couple of different switch options since I can't decide which type I like best.
Old 04-25-2009, 07:29 AM   #144
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
mine was supposed to be delivered today but I wasn't home, I'm going to pick it up at the post office tomorrow.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 02:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
