Old 04-24-2009, 12:46 PM   #19
b_hickman11
Drives: 08 Sedan
Bleach is about the most corrosive substance there is for steel.
You dont leave it in there. Poor it in...give it a few minutes to eat at the mold...then wash it out with a water hose.
Old 04-24-2009, 01:21 PM   #20
Lafiro
Drives: 06 Yaris Sedan
I need pictures of where to do this from the outside.
Also, for me 75% of the smell is now gone after spraying the inside of the ducts with antimicrobial febreeze, and then sprayed it all around the cabin air filter compartment and itself when on at full blast.
Then 3 nights of full blast Ionic Breeze(creating Ozone) finally helped a lot of it.
Now my car smells like new, well like Nothing to be more specific. But the A/C did today smell for about 20 seconds just a little bit. So something is still wrong then.
Have to have this fixed before Monday when my girl comes back home.
Old 04-24-2009, 04:30 PM   #21
sdyaris
Drives: 2010 Nissan Frontier Pro 4x
pointless post
How about a helpful post Morgan? At least provide a link to the "TSB" thread.
Originally Posted by Morgan View Post
There is a TSB for the smelly a/c ... search function anyone?
sdyaris is offline   Reply With Quote
Old 04-24-2009, 04:38 PM   #22
Forrest
Drives: 08 LB BLACK
I am almost afraid to turn on ac when we get a warm day !!!!!!!!!!! Some molds are really bad to breath in and this is a concern if it does grow in the vents. Does Toyota have a solution to mold? besides antibacterial sprays?
I have never had a car that had a bad smell from the ac and dread it if the Yaris becomes the first.
Forrest is offline   Reply With Quote
Old 04-24-2009, 04:56 PM   #23
33OH
Drives: '08 Yaris
The TSB only seems to be for '07 and older Yarii.
http://www.etimago.com/yaris/TSB/T-A...20Odor%20).pdf
Old 04-24-2009, 09:13 PM   #24
vector9mm
Drives: blue 08 hb
Had a bad smell in my other car when I turned on the fan. It was a dead mouse in the fan.
vector9mm is offline   Reply With Quote
Old 04-25-2009, 10:00 PM   #25
GeneW
Drives: 2008 Yaris
Originally Posted by captainm27 View Post
So I turned the A/C on today, being months without use in the winter. Everything works out well, up until 10 minutes later, when the evil A/C stench decides to rear it's ugly stenchiness. Sheesh! What a treat I got for driving a nice spring day. I did the custom cabin air filter using BailOut's guide, thinking it might help. Alas, not even a strong NaturalAire home filter can withstand the might of the A/C stench.
Sometimes I get a "plastic" smell coming from the AC vents. I don't run the AC too often, except sometimes on long hills. Waste not, want not.
Gene
Old 04-25-2009, 10:03 PM   #26
GeneW
Drives: 2008 Yaris
Originally Posted by b_hickman11 View Post
poor some bleach in the vents on the outside of the car at the bottom of the windshield where the wiper blades arms attach to the car.
If you knew what bleach does to steel you'd never pour it into or near your car. I've seen bleach rust some kinds of stainless steel, as in crusty rusted stainless. Never would have believed it if I hadn't seen it myself.
Bleach is absolute murder on carbon steel.
A more gentle cleanser, one that doesn't attack metal may be in order. Don't know of one offhand.
Gene
Old 04-26-2009, 07:36 PM   #27
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
It also helps to turn-off the A/C but leave the fan on a few minutes before you turn off your car. This dries up the moisture in the ducts and vents to help prevent any mold from growing. Most of (if not all) the smell should be gone the next time you start your car
Old 04-26-2009, 11:21 PM   #28
b_hickman11
Drives: 08 Sedan
Gene
Use non-chlorine bleach then....
Old 04-27-2009, 11:33 AM   #29
Lafiro
Ok, so I tried using the AC and then turning it off, and got a constant bad smell, not as bad, but still. So I sprayed it into the went intake from the outside, and it still was the same. So maybe the antimicrobial spray is not enough or strong enough to help?
I need to fix this, its so pathetic.
Old 04-27-2009, 07:09 PM   #30
haku
haku's Avatar
Drives: sentra
Send a message via AIM to haku
yup, this is how to do it... dunno what's with all these crazy suggestions... alternatively, you can just run the a/c without the engine on. it has the same effect.
haku is offline   Reply With Quote
Old 04-27-2009, 08:41 PM   #31
captainm27
Drives: 2008 Sedan A/T Silver
I just don't know why the Yaris is the only car that I know that does this. My previous 4 other cars never had a smell issue with the AC, and they were much older vehicles. I used to keep the AC setting on through the whole summer with my other cars, and never once had the stench that comes out of the Yaris. Could it be that since the Yaris has such a small engine, their is not enough airway passages in the vents?
captainm27 is offline   Reply With Quote
Old 04-27-2009, 09:14 PM   #32
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
I smell a recall. I stoped circulating the AC and now just pull it from outside cause of the smell.
Club SHIFT
Old 04-27-2009, 09:25 PM   #33
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
so if my car's out of warranty, what do you think my chances are of having the dealership fix it according to the tsb and not being charged for it? =P
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 05-31-2009, 01:41 PM   #34
dccurrent
Drives: Yaris 5 door Liftback
This is interesting because I smell it when I am just running the air with no AC on, but when I turn it on the smell goes away.
dccurrent is offline   Reply With Quote
Old 06-03-2009, 12:55 PM   #35
captainm27
Same thing happens to me. In order to aviod the stench, I must keep the A/C button turned on always.
Old 06-03-2009, 01:50 PM   #36
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
depends on dealership and your actual service history with them. have you ever had your compaint documented when you were in for service/s? they COULD goodwill it......
shoot me a pm with an email address. i have something you'll be interested in and hopefully will post for everyone else.....
