Old 04-27-2009, 06:47 PM   #1
Syroyizhka
Syroyizhka's Avatar
Drives: 2007 Yaris Hatchback
Question Where can i get constant power from?
I installed power windows, and getting power from cig lighter was a terrible idea, my neons fade when i use close/ open windows, i need a pic to show me where i can get constant power from, or even ignition power.
Syroyizhka is offline   Reply With Quote
Old 04-27-2009, 06:55 PM   #2
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
courtesy CTScott... where the red wire is coming from is a 12v constant. it's located behind the sunglasses case on the left side of the steering wheel
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 04-27-2009, 07:12 PM   #3
Syroyizhka
Syroyizhka's Avatar
thank you, my auto starter is connected to that, um...any other ones, would be a good idea to share that one for 2 sources?
Old 04-27-2009, 07:15 PM   #4
enobmort42
First time DIYer
enobmort42's Avatar
hmm. electric talk isn't my forte, but maybe you can add-a-fuse in the box and run it through? maybe someone else can be a little more specific as to the size fuse you'd want if you do do that..
http://img210.imageshack.us/img210/5...6081022dt5.jpg
Old 04-27-2009, 07:32 PM   #5
360cubes
Drives: 2000
Send a message via MSN to 360cubes
Check for a fuse that's not in use. You should be able to wire it to the fuse (panel under the hood is best option). The last resort is to look for a wire that splices off from the main battery terminal. As long as it isn't the heavy gauge wire coming off the battery you'll be fine to connect it to that. I installed off road lights this way. Anything other than connecting it directly to the battery terminal is fine as you don't want to push too much power through a small gauge wire should a fault occur, or you'll have a nice toasty Yaris....
360cubes is offline   Reply With Quote
Old 04-27-2009, 08:13 PM   #6
I'd suggest using Pin 2 or Pin 11, of connector 4H. It is a 30A fused feed which feeds the power windows on a car with power windows. On my 09 there is a blue wire in 2 and a a grey wire in 11.
Old 04-29-2009, 09:59 PM   #7
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
you need to get a voltage stabilizer. that would eliminate the drain in power you get when you open/close your windows or use any other feature with electric power. i have have one on my car for over 300,000 miles and i have HID's in my headlights and fog lights and a small amp in my trunk and i don't get a dip on my power when i use any other electric power.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 04-29-2009, 11:08 PM   #8
texkid
The one with cheese on it
Drives: '10 Corolla S
Same spot, different angle. This is from when I installed my rechargeable flashlight. I had to attach a 2 amp fuse.
texkid is offline   Reply With Quote
constant power
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Power Enterprise Super Charger Kit Round 2 $3100 Power Enterprise Evan Forced Induction Forum 312 03-26-2009 06:48 PM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
Constant power, always on, sidemarker lights w/ switch... reznunt DIY / Maintenance / Service 17 07-15-2007 11:59 AM
