Old 04-25-2009, 09:03 PM   #1
CanadianHiFive2
Drives: Sedan
Need Help Figuring this out
Ok so today, I was at the local audio store looking at some stuff and when i went to my car the door opened with the auto key and then when i go to start the ignition, car wont start! I wait 2 minutes and nothing still. The only thing i have hooked up to my battery is a 200 Watt amp. I went and unhooked the amp and the car started! What could be going on? The amp is wired so that it only turns on when the head unit turns on and im using an 8 guage wire to hook it up from the + end of the battery to the amp
Any ideas
CanadianHiFive2 is offline   Reply With Quote
Old 04-25-2009, 09:31 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
double check your grounds.. did you fuse the power wire going to the amp?
Originally Posted by xnamerxx
you nailed it sir.
Old 04-25-2009, 10:04 PM   #3
CanadianHiFive2
Drives: Sedan
Ya there is a 60A fuse running close to the battery and the ground is connected to a screw i found in my trunk
Old 04-25-2009, 10:31 PM   #4
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
Did you sand the area around that screw for the ground? May not be getting good contact if there's paint in the way.
wsladaritz is offline   Reply With Quote
Old 04-26-2009, 12:05 AM   #5
CanadianHiFive2
Drives: Sedan
I believe it is grounded properly cause this only happened twice so far and the amp has been in there for 4 months
Old 04-26-2009, 12:22 AM   #6
CanadianHiFive2
Drives: Sedan
would it be possible that water was touching the positive part of the battery and shorting it out?
Old 04-29-2009, 02:43 AM   #7
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
maybe... i'm not really sure about that though. It would have to be enough water to allow the positive and negative sides to touch... i think.
Old 04-29-2009, 03:52 AM   #8
CanadianHiFive2
Drives: Sedan
ok so it happened again today except i actually needed a boost to get it started and then when i shut it off i needed another boost! Im starting to think i need a new battery? What do u think any suggestions on a specific type
Old 04-29-2009, 05:49 AM   #9
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i think you need a new battery or alt not working so good
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 04-29-2009, 01:15 PM   #10
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Take the fuse out of the power line on the amplifier so that it doesn't turn on. If you're at an audio shop, they should have a battery charger hanging around somewhere. What I'd do is to ask them to hook up the car's battery and charge it for a while. Now, if you take the car off the charger and it dies after a little while AFTER YOU ARE ABLE TO TURN THE ENGINE OVER...you'll probably notice that you have a nasty rough idle...your alternator is dead.
The dealership SHOULD be able to replace the alternator under warranty. Just make sure they know that the sound system is fused and grounded properly so they can't bite you in the a$$ saying that it was the system that caused the alternator failiure. I honestly can't see a Toyota dealer doing that the first time you bring it in though.
― Thomas Paine
Old 04-29-2009, 07:26 PM   #11
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
I can see that happening... I don't what toyota is like elsewhere, but here in East Texas they're a bunch a douche bags! It took me four trips up there after I bought my car to finally figure out they weren't gonna help me with shit after they made the sale... I kept thinking if I talked to a different person up there they would be more helpful or understanding. I was wrong
Sorry... not tryin to hijack the thread!
*climbs down off soap box*
Old 04-29-2009, 07:27 PM   #12
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
do what sqcomp said though, I think he's got the right idea.
Old 04-30-2009, 02:48 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That $ucks to hear about the dealership! You should run the car through the front window of the dealership and start taking hostages!
Juuuuuuuuuuusst kidding.
― Thomas Paine
Old 04-30-2009, 06:45 PM   #14
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
hmmm.... that sounds like it might be fun! If there was like a rewind button or something
Old 05-01-2009, 03:07 AM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
hey Canadian...
What is the fuse rating on the amplifier? Aside from that it really sounds like your alternator quit on you.
― Thomas Paine
