| View Poll Results: are you interested? | |||
| yes i'm interested in 13mm spacers |
13 | 48.15% |
| yes i'm interested in 10mm spacers |
14 | 51.85% |
| Voters: 27. You may not vote on this poll | |||
Gauging interest on hub spacers for the yaris
i'm getting ramped up to build more hub spacers and want to get a semi-accurate count on how many i should build.
please choose "yes" in the poll if you'd be interested in spacers @ $75shipped to continental US (and reasonable shipping to canada too of course) ![]() ![]() if the results are favorable i'll be getting a vendor account here :)
Beast
ChaChaChaChino
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
can i have a moderator edit this to become a public poll? thanks
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
pm tk-421, he's been looking for this!
Riceman43
What do these actually do for you...
they allow you to get your vehicle's track width closer to equal. the car normally comes with about 1" wider track front vs rear.
one of those "little" mods that you can actually feel in the corners they also allow you to buy a "proper" offset wheel for the front of your car and space the rear out to look more flush (without rubbing). they're "better" than wheel spacers, as they do not require you to have longer lug bolts, and because you're spacing the HUB not the WHEEL, you do not see as much wear on wheel bearings. will come with class 12.9 socket head capscrews (allen head) and hardened washers.
Apexing Egg!!
do you think you could make some that reduce the toe?
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
very difficult to do that, as i don't know the specific drop your car has. as the suspension compresses, negative camber turns into toe-in.
i could, however, provide two stainless washers to be installed under the lower front bolt. this is how i achieved my current setup (toe out, and a little extra camber)
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
I've got the v 1.0s on our Yaris currently and they are great. Getting a 2nd set of 13mm's is kind of tempting though.
Keep me posted on the progress of this, count me in. :) |
#10 | |
or were you thinking to ADD 13mm to your current 10mm? ![]()
l33t3st Asshole
![]() I was thinking of swapping the 10s for the 13s. and keeping the 10's just in case. the price is too good not to have 2 different sets, having the flexibility to easily change the rear spacing when I buy new wheels is really comforting. |
what's the difference between the 2 and do you think i need this mod?
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#13 | |
the other is 13mm wide so the difference is 3mm ![]() what wheel/tire are you running, and on what suspension?
#14 |
l33t3st Asshole
I think Every Yaris needs this, it really changes the handling/look, as they say you "need" a +42mm in the front to avoid rubbing, but you don't "need" a +42mm in the rear, hell I'm running a +25mm effective offset in the rear right now. :)
#15 | |
im stupid so the extra 3mm means it will stick out further than 10mm?
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
The extra 3mm means it'll stick out 13mm, yes.
#17 | |
l33t3st Asshole
stick out isn't the correct term. it will push the wheel outward 13mm total from where it is now. it will not stick out unless you have an offset of 30mm or lower to start with. |
#18 |
+42 i think
| WANTED - Stock 15" 2007 Yaris HUB CAPS! | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-29-2006 07:09 PM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
