![]() ![]() ![]() Drives: 07 5spd red Yaris HB 1.5L 16V Join Date: Oct 2006
@#^#@%#*@#^--error
#2 | |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
Yup, and it's a major pain... first un clip all the little black pop-clips under the hood and the two where the bumper meets the fender. Then pull carefully at the sides by the fenders until the tabs pop loose, now you can lower the bumper a bit to get a look behind, what you'll need to do is get a flat tool you can use to pry the clips all the way around the grille loose, I'd recommend the top first, then the bottom. |
#3 | |
#4 | |
Ηave you found anything better than the stock grill?
#6 | |
I read somewhere on here that you can take the front grill out without taking off or loosening the rear bumper, with the help of some dainty hands. Find a hardcore chick. |
#7 | |
| Hatch back and HKS power | nun73 | Cosmetic Modifications (Exterior/Interior) | 28 | 10-16-2006 06:49 AM |
