#19 | |
Drives: 2008 Yaris Join Date: Oct 2008
I ran straight pipes on a 75 Chevy Nova for about a year. Reduced the mileage somewhat and I didn't have an ECU that had more computing power than some 1970s vintage fighter jets in it either. Gene |
#20 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
The driver affects the mileage way more then any muffler will
Its the ECu's job to control the fuel system , using the MAFS and O2 sensor readings it will comtrol the amount of fuel needed to maitain the same fuel air mixture... If one did modify the exhaust so that the engine combustion scavenging is greatly effected and fuel is being waisted... the o2 sensor will pick up the overly rich combustion gasses leaving the cylinders and the ECU will alter the fuel and timing to help control it to maintain the factory set air fuel ratio. Sure this may cost you a MPG or two at the most but, I have found in most cases everything kept the same just freeer flowing muffler actually improved MPG. its not until you get into different intake designs, and complete exhaust systems that you see major mileage changes Changing the exhaust will slightly alter how efficiently the engine will combust the fuel mixture but on a car with an exhaust system like the yaris (these things have what 3 cat convertors?) VVT-i, the elaborate ECU system the effects from a free flowing exhaust will be very small. The biggest issue with an open exhaust is the driver... As a motorcycle mechanic I'm asked this daily and deal with this everyday. Why after changing to louder pipes and re-jetting does it use so much more fuel... The answer... the operator. With a quiet exhaust people tend to ride it or drove it much easier.. why because there is nothing impressive there... however with a loud exhaust people like to HEAR that exhaust and 90% of the time accelerate much harder and to much higher RPMs... I have explained to many customers that before thier exhaust they would putt putt through town, now you can hear them honkin on it 4 blocks away... You don't hear the guys on the Stock Hondas and Harleys flogging on it WOT through the gears like the guys with open drag pipes or fart can exhaust.... I challange anyone to drive /ride the same way with both quiet and open exhaust and you will usually find a very small change in MPG.. I understand there is no fun in that though. I rode my GSX750F for a year with no problems, got 2 speeding tickets within a week after my new Hindle race pipe.... My mileage on the hwy actually went up slightly if I maintain a steady cruise speed, however now that i find myself shifting at red line or higher rpms a lot more fuel mileage suffers a lot when i'm accelerating like a tool...but man o man the pipe sounds sweet.
The early bird gets the worm, but the second mouse gets the cheese. |
#21 |
toyota
anyways i got it on..i got it on and its louder than i wanted atleast on the inside..outside wise its sound wicked..but the internal drone is annoying me..*sigh* time to adda resonator.. i going for extra flow not extra loud..damn it.
#22 |
Pics?
#23 | |||||
I've had cars with plugged catalytic converters..... once the exhaust is sufficiently restricted things get complicated.... Mileage drops off, power is awful and the motor runs hotter. Quote:
Wide band sensors don't have this problem but they are pricey. The electronics is also pricey. The calibration of the wide band system is EXTREMELY pricey. As I said in my "explanation" - the devil and salvation are in the details. You have to measure the results of changing the exhaust system. Quote:
Opening the jets will make the mixture richer, and MAY improve fuel efficiency if you're sufficiently close to Stoichometric on average. Quote:
Gene |
#24 |
toyota
here it is..
#25 | |
HardlyDangerous
But again i deal with bikes on a daily basis not cars but these engines all basically work the same. many of my race engine are dialed in using CHT and EGT as well as proper plug reading... Simple changes like header size and diameter, header shape and length, exhaust size and silencer can and will alter how efficiently the engine runs.. Even a simple slip on/bolt on muffler often requires rejetting. With EFI bikes the fuel maps are changed to correct any lean or rich mixtures when changing exhaust set ups There would be no need to rejet or re-map if the efficiency of the engines combustion never changes. An engine runs leaner when more burnt gasses are allowed to escape, when burnt gasses are kept in the combustion chamber this dilutes the mixture and the power output... Some engines respond much better then others to minor changes and require much larger changes, other it makes very little but a lot of that has to do with valve overlap etc.
#26 | |
Gene |
| Using DFCO to increase your MPG | BailOut | Fuel Economy Forum | 216 | 08-30-2018 05:15 AM |
| 42.04 MPG straight off the lot! | bnther36 | General Yaris / Vitz Discussion | 25 | 05-17-2010 07:09 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 07:31 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 05:23 PM |
| To accurately measure MPG when should I fill back up. | mgthompson | General Yaris / Vitz Discussion | 17 | 03-30-2007 11:07 PM |
